Dragon II是A830的升级版吗? |
应该不是吧。 账目性能都差不多。Alpha Dragon II "Worlds Edition" Specifications: Displacement: 3.49cc Bore: 16.26mm Stroke: 16.8mm Practical RPM: 4,000 - 40,300rpm Power Output: 2.80PS/38,800rpm Weight Approx: approx. 361g Ports: 3 Ports Sleeve: ABC Crankshaft: Dynamic Equilibrium Crankshaft w/Special Material Crankshaft Diameter: 14mm Glow Plug Type: Turbo Exhaust: Rear Carburetor Diameter: 8.8mm (Variable) Case Material: Aluminum Carburetor: 3 Needles 数据上好像还Ryan Lutz Worlds Edition的马力大。 Specifications: Displacement: 3.45cc Bore: 16.26mm Stroke: 16.8mm Practical RPM: 4,000 - 40,000rpm Power Output: 2.900PS/39,900rpm Weight Approx: 352g Ports: 5+2 Ports Sleeve: ABC Crankshaft Diameter: 14mm DEC Glow Plug Type: Turbo Exhaust: Rear Carburetor: 8mm (Variable) Case Material: Aluminum |
