[产品信息] Power HD 1235MG 国外用户舵机测试
查看: 9305|回复: 0| [复制链接]
发表于 15-6-12 09:20:53 |显示全部楼层 来自: 中国广东惠州
What's next?
Now we know the servo's are looking good and have some impressive specs it is time to build. These servo's have some different dimensions which is not an issue at all. Most of the servo's have different sizes and these Power HD are in the range of the Hitec Rhino Digi-4. So a bit smaller than the Savox 0235/0236. The horn gear spline has a diameter of 8.8mm and counts 17T so this is also different than we are familiar with. All hardware such as horns are included so we will see these servo's working very soon. Xander Agterbosch will drive a dual steering servo setup in his Shortcourse Losi 5ive-T, Ralf van Hattum will use a servo on Throttle / Brake.
Our expectations are really good. There are already some tests with Power HD servo's (not the 1235MG's) and are all really positive. Hopefully the problems with servo's are history. Stay tuned for our test results!
(内容转载国外 翻译)
Power HD 1235MG 舵机测试
国外用户观点评价:众所周知的一点, PowerHD 舵机性价比高,跟SAVOX 舵机价格接近,比Hitec舵机便宜好多,这是做这个报告的重要原因之一。
1235MG 是一款高压舵机, 当锂电压达到7.4V 时,扭力高达40kgs/cm,  速度达到了0.18s。 锂电压达到6.0v ,扭力为35kgs/cm,舵机安装上车后,目前我们知道了PowerHD 舵机 看起来不仅美观大方,性价比高,还有其他不同与别家的特别之处。
1235MG舵机拥有不同于其他舵机的尺寸,但是这完全不应影响舵机的使用。我们知道不同牌子的舵机都有各自的尺寸规格, POWER HD 的1235MG 尺寸介于 Hitec Rhino Digi-4 跟Savox 0235/0236 之间,它的齿距8.8mm,17T的齿数也异于我们所熟知的其他牌子的舵机。这款舵机跟模型配合起来非常好,Xander Agterbosch 把1235MG 安装在他的Losi 5ive-T车转向位置中,Ralf van Hattum 把舵机安装在了油门上。。。
期待测试结果....
