[电子设备] KO和SANWA全系列驼机参数
查看: 3117|回复: 5| [复制链接]
小麦 论坛元老 发消息
发表于 07-1-17 03:04:55 |显示全部楼层 来自: 中国广东广州
请问有无人有KO和SANWA全系列驼机的参数啊?有的请发上来..谢谢..
cbq 金牌 Fans 发消息
发表于 07-1-17 10:32:28 |显示全部楼层 来自: 中国浙江台州
KO Propo
Servo # Description Weight Dimensions Torque 4.8V / 6.0V Speed Motor/ Bearings Notes
oz-in Volts@
(W x L x H) kg-cm
KOPM1100 Metal Gear Servo 2.1 oz 0.83 x 1.5 x 1.6 in 97 oz-in 0.06 sec 4WD steering; heavier electric models
(59.6 g) (20 x 38 x 41 mm) (7.0 kg-cm) 7.2v @ 60 deg
KOPM1101 Metal Gear Servo 2.1 oz 0.8 x 1.5 x 1.6 in 91 oz-in 0.08 sec Throttle; nitro models
(59.6 g) (20 x 38 x 41 mm) (6.5 kg-cm) @ 60 deg
KOPM1104 Metal Gear Servo 2.1 oz 0.8 x 1.5 x 1.6 in 104.5 oz-in 0.13 sec 4WD steering; heavier nitro models
(59.6 g) (20 x 38 x 41 mm) (7.5 kg-cm) @ 60 deg
KOPM1115 Ultra high speed 1.8 oz 0.8 x 1.5 x 1.6 in 100.4 oz-in 0.05 sec 4WD steering; ultra-quick response in electrics
(51.1 g) (20 x 38 x 41 mm) (7.2 kg-cm) @ 7.2v @ 60 deg @ 7.2v
PDS763 ICS Digital Progammable 1.59 oz 0.83 x 1.38 x 1.61 in 90.3 oz-in 6 0.14 sec plastic gears
(45.08 g) (21.01 x 35.05 x 40.89 mm) (6.50 kg-cm) @ 60 deg @ 6.0v
PDS764 ICS Digital Progammable 1.59 oz 0.83 x 1.38 x 1.61 in 104.2 oz-in 6 0.16 sec plastic gears
(45.08 g) (21.01 x 35.05 x 40.89 mm) (75 kg-cm) @ 60 deg @ 6.0v
PDS949 Digital Hi Speed Progammable 0.95 oz 0.59 x 1.28 x 1.42 in 38.8 oz-in 6 0.09 sec metal gears, dual ball bearings
(26.93 g) (14.99 x 32.51 x 36.07 mm) (2.80 kg-cm) @ 60 deg @ 6.0v
PDS2123 FET Digital High speed 1.9 oz 0.8 x 1.5 x 1.6 in 131.7 oz-in 7.2 0.06 sec coreless, metal gears, dual ball bearings any cars
(55.0 g) (20 x 38 x 41 mm) (9.5 kg-cm) @ 7.2v @ 60 deg @ 7.2v
PDS2343 FET Digital High Torque 1.9 oz 0.8 x 1.5 x 1.6 in 111 oz-in 6 0.08 sec metal gears, dual ball bearings any cars
(55.0 g) (20 x 38 x 41 mm) (8.0 kg-cm) @ 60 deg
PDS2344 FET Digital High Torque Programmable 1.9 oz 0.8 x 1.5 x 1.6 in 111 oz-in 6 0.08 sec metal gears, dual ball bearings any cars
PDS2363 ICS Digital Programmable 1.99 oz 0.8 x 1.5 x 1.6 in 111 oz-in 6 0.08 sec metal gears, dual ball bearings Heatsink
(28.07 g) (20 x 38 x 41 mm) (8.0 kg-cm) @ 60 deg @ 6.0v
PDS2364 ICS Digital Programmable 1.99 oz 0.8 x 1.5 x 1.6 in 180 oz-in 6 0.13 sec metal gears, dual ball bearings Heatsink
(28.07 g) (20 x 38 x 41 mm) (12.97 kg-cm) @ 60 deg @ 6.0v
PDS2365 ICS Digital Programmable 1.99 oz 0.8 x 1.5 x 1.6 in 111 oz-in 6 0.08 sec metal Hybride gears, dual ball bearings Heatsink
PDS2366 ICS Digital Programmable 1.99 oz 0.8 x 1.5 x 1.6 in 180 oz-in 6 0.13 sec metal Hybride gears, dual ball bearings Heatsink
PS-401 High Speed Almighty Servo 1.65 oz 0.83 x 1.6 x 1.38 in 44.3 oz-in 6 0.16 sec Plastic gears any cars
(47 g) (21 x 41 x 35 mm) (3.2 kg-cm) 6v @ 60 deg 6v
PS-712 FET High Torque FET Servo 1.68 oz 0.83 x 1.6 x 1.38 in 61.0 oz-in 0.12 sec GP-10 cars
(48.1 g) (21 x 41 x 35 mm) (4.4 kg-cm) @ 60 deg
PS-713 FET High Speed FET Servo 1.68 oz 0.83 x 1.6 x 1.38 in 73.4 oz-in 0.10 sec GP-10 cars
(48.1 g) (21 x 41 x 35 mm) (5.3 kg-cm) @ 7.2v @ 60 deg @ 7.2v
PS-947 FET Digital Mini Power Servo 0.95 oz 0.59 x 1.28 x 1.42 in 38.8 oz-in 0.09 sec coreless, metal gears, dual ball bearings any cars
(27 g) (15 x 32.5 x 36 mm) (2.8 kg-cm) 6v @ 60 deg 6v
PS-2001 FET High Speed Servo 1.8 oz 0.8 x 1.5 x 1.6 in 90 oz-in 6 0.08 sec coreless, dual ball bearings, metal gears any cars
(51.1 g) (20 x 38 x 41 mm) (6.5 kg-cm) @ 6v @ 60 deg @ 6v
PS-2004 FET High Torque Servo 1.8 oz 0.8 x 1.5 x 1.6 in 104 oz-in 6 0.13 sec coreless, dual ball bearings, metal gears any cars
(51.1 g) (20 x 38 x 41 mm) (7.5 kg-cm) @ 6v @ 60 deg @ 6v
PS-2015 FET High Speed Lightweight Servo 1.79 oz 0.8 x 1.5 x 1.6 in 100.4 oz-in 7.2 0.05 sec coreless, dual ball bearings any cars
(51.0 g) (20 x 38 x 41 mm) (7.2 kg-cm) @ 7.2v @ 60 deg @ 7.2v
PS-2113 FET High Speed FET Servo 1.76 oz 0.8 x 1.5 x 1.6 in 131.7 oz-in 7.2 0.06 sec plastic gears any cars
(50.0 g) (20 x 38 x 41 mm) (9.5 kg-cm) @ 7.2v @ 60 deg @ 7.2v
PS-2133 FET High Speed FET Servo 1.76 oz 0.8 x 1.5 x 1.6 in 111. oz-in 6 0.09 sec plastic gears, 2 ball bearing any cars
(50.0 g) (20 x 38 x 41 mm) (9.5 kg-cm) @ 6v @ 60 deg @ 6.0v
PS-2143 FET Digital High Speed Servo 1.93 oz 0.8 x 1.5 x 1.6 in 111.0 oz-in 6 0.08 sec coreless, metal gears, dual ball bearings any cars
(54.5 g) (20 x 38 x 41 mm) (8.0 kg-cm) @ 6.0v @ 60 deg @ 6.0v
PS-2144 FET Digital High Torque Servo 1.9 oz 0.8 x 1.5 x 1.6 in 180.5 oz-in 6 0.13 sec coreless, metal gears, dual ball bearings
(54.2 g) (20 x 38 x 41 mm) (13.0 kg-cm) @ 6.0v @ 60 deg @ 6.0v
PS-2173 FET High Speed Power Servo 1.93 oz 0.8 x 1.5 x 1.6 in 111.0 oz-in 6 0.09 sec coreless, metal gears, dual ball bearings
(54.5 g) (20 x 38 x 41 mm) (8.0 kg-cm) @ 6v @ 60 deg @ 6v
PS-2174 FET High Torque Power Servo 1.93 oz 0.8 x 1.5 x 1.6 in 166.3 oz-in 0.13 sec coreless, metal gears, dual ball bearings
(54.5 g) (20 x 38 x 41 mm) (12.0 kg-cm) @ 6v @ 60 deg @ 6v
PDS-3014 ICS digita lmicro programmable ? ? 27.75 oz-in ? 0.11 sec metal gears, dual ball for 1/18th scale and smaller vehicles
? ? (2.0 kg-cm) @ 60 deg @ 6v
PDS-8044 ICS Digital Programmable 5.02 oz 2.35 x 1.15 x 2.09 in 333 oz-in 6 0.20 sec metal gears, dual ball
(142.31 g) (59.69 x 29.21 x 53.07 mm) (23.98 kg-cm) @ 60 deg @ 6v
发表于 07-1-17 13:14:52 |显示全部楼层 来自: 中国浙江杭州
KO Propo
PDS-2123FET 0.06s 9.5Kg/cm 7.2V/Digital/金屬 EP 1/10
PDS-2143FET 0.08s 8.0Kg/cm 6V/Digital/金屬 EP 1/10
PDS-2144FET 0.13s 13.0Kg/cm 6V/Digital/金屬 EP, GP 1/10
PDS-2343FET 0.08s 8.0Kg/cm 6V/Digital/金屬 EP 1/10
PDS-2344FET 0.13s 13.0Kg/cm 6V/Digital/金屬 EP, GP 1/10
PDS-947FET 0.09s 2.8Kg/cm 6V/Digital/金屬 EP 1/12, 1/18
PS-2173FET 0.09s 8.0Kg/cm 6V/Analog/金屬 EP 1/10
PS-2174FET 0.13s 12.0Kg/cm 6V/Analog/金屬 EP, GP 1/10
PS-2113FET 0.06s 9.5Kg/cm 7.2V/Analog/金屬 EP 1/10
PS-401 0.16s 3.2kg/cm 6V/Analog/膠 EP 1/10
ps2001 0.09秒,6.5Kg力
ps2004 0.13秒,8kg力
发表于 07-1-17 13:15:03 |显示全部楼层 来自: 中国浙江杭州
Sanwa
ERG-VR 0.07s 8.0Kg/cm 6V/Digital/金屬 EP 1/10
ERG-VB 0.10s 13.0Kg/cm 6V/Digital/金屬 EP, GP 1/10
ERG-VX 0.10s 13.0Kg/cm 6V/Digital/金屬 EP, GP 1/10
ERG-VRX 0.07s 8.0Kg/cm 6V/Digital/金屬 EP 1/10
ERG-WRX 0.06s 8.1Kg/cm 6V/Digital/金屬 EP 1/10
SX-101Z 0.18s 3.3Kg/cm 6V/Analog/膠 EP 1/10
SX-112 0.14s 4.0Kg/cm 6V/Analog/膠 EP 1/10
SDX-755 0.11s 5.8Kg/cm 6V/Digital/金屬 EP 1/10
SRM-141HRZ 0.07s 2.3Kg/cm 6V/Digital/金屬 EP 1/12, 1/18
tqchan 论坛元老 发消息
发表于 07-1-18 20:18:04 |显示全部楼层 来自: 中国上海
数据有误
牛拉车 论坛元老 发消息
发表于 07-2-10 00:11:54 |显示全部楼层 来自: 中国广西南宁
太感谢了``````````
