XQ-POWER SERVO XQ-S4330D :一款專為車打造的一款高端數碼舵機,標準尺寸外觀, 全金屬CNC外殼,標準電壓4.8-72V電壓,30KG超大扭力數碼舵機 具體參數如下 Name:6V30kg-cm Digital Servo; Size :A:40.2mm B:20.1mm C:38.8mm D:48.0mm E:10mm; Weight:65g ±0.2(2.29oz); Gear type:Titanium Gear; Speed:0.18sec/60o at (6.0V) 0.20sec/60o at (4.8V) Torque:(416.6 oz-in)30kg.cm.at(6.0V) (374.9 oz-in)27kg.cm.at(4.8V) Features:Waterproof,tamper-proof servo wire, All Aluminium CNC case, easy to eliminate heat and corrosion;Adopt high quality coreless motor. 舵機圖片: XQ-S4330D可提供兩種不同外觀供貨 |
