是用7.8V还是11.1V?可不可以用11.1V的3S电池?谢谢各位。 Specifications: Custom Designed for True to Scale Looks Realistic Aluminum Ladder Frame Chassis 5 Lug Wagon 1.9 Steel Stamped Beadlock Wheels (Black) Dirt Grabber 1.9" All Terrain Tires Yota II Ultimate Scale Cast Axle R3 Single Speed Transmission Center Mounted Realistic 4x4 Transfer Case Cast Metal Axles with Locked Differentials 3 link front and 4 link rear suspension Gelande 2 Chassis Plastic Rod Ends Full Ball Bearings ARB Diff Covers Scale Steel Punisher Shaft V3 Rock Krawler RRD Emulsion Scale Dual Spring Shocks Gelande Front Winch Bumper RC4WD 1/10 Warn 9.5cti Winch 540 Crawler Brushed Motor 45T Outcry Crawler Dual Motor ESC w. Fan & TurboBEC Twister High Torque Metal Gear Digital Servo XR4 4-Channel 2.4Ghz Transmitter/Receiver Radio RC4WD Wired Winch Control Unit RC4WD Spare Tire Case For Defender Body 1/10 Land Rover Defender D90 Limited Edition Pre-painted Yellow Body Gelande Side Rock Sliders Length: 22.91in / 582mm Width: 8.7in /221mm Height: 10.24in / 260mm Wheelbase: 10.63in / 270mm Weight: 141.8oz / 4.02kg |
