豆豆开汽车 元老 Fans 发消息
发表于 15-3-19 15:42:20 |显示全部楼层 来自: 中国北京
接杯看上去应该不错
韬涛 金牌 Fans 发消息
发表于 15-3-19 15:45:37 |显示全部楼层 来自: 中国广东深圳
SCT410与SCT410.3的零配件区别:
首先是车架的区别:
TKR5016B – Gearbox (rear, angled)
TKR5049A – Pivot Balls (6.8mm, no flng, sway bar, shck ends, almnm, 4pcs)
TKR5052A – Pivot Balls (6.8mm, inside camber, steering links, aluminum, 4pcs)
TKR5053A – Pivot Balls (6.8mm, flanged, outside camber, aluminum, 4pcs)
TKR5058A – Pivot Balls (5.8mm, no flange, brake/steering link, aluminum, 4pcs)
TKR5079A – Stabilizer Balls (6.8mm, sway bars, aluminum, 4pcs)
TKR5165 - V2 Hinge Pin Inserts, Wheelbase Shims (EB/NB/ET/NT/SCT)
TKR5188 - Rod Ends (6.8mm, M4 thread, SCT/SL, 8pcs)
TKR5212 – LCG Motor Mount Insert (aluminum, gun metal ano)
TKR5260 - CNC Split Cntr Diff Mount (mtr mnt only, 7075, gun metal ano, EB/ET/SCT)
TKR5263 - Split Cntr Diff Mount (composite, requires TKR5260, EB/ET/SCT/SL)
TKR5288 – Chassis (7075, black anodized, lightened)
TKR5491 - Sway Bar (2.4mm, rear)
TKR5515 - Suspension Arms (rear, SCT.3/SL)
TKR5516 - Suspension Arms (front, SCT.3/SL)
TKR5518B – Front Bumper Set (SCT410)
TKR5541B - Spindles (6x13x5mm outer bearing, L/R, SCT410/EB48SL)
TKR5545 - Rear Hubs (L/R, CV or uni, SCT.3/SL)
TKR5548 – Decal Sheet (SCT410.3)
TKR5554A – Spindle Bushings (SCT410, 4pcs, aluminum, hard ano)
TKR5555A – Arm Bushings (SCT410, 4pcs, aluminum, hard ano)
TKR5570B – Stub Axles (SCT410, hardened steel, 2pcs)
TKR5571M - Wheel Hexes (steel w/ set screw, lightened, 12mm, SCT410/SL)
TKR5575X – Diff Coupler (SCT410, f/r, hardened steel, lightened)
TKR5579 - Tapered Driveshaft (SCT/EB48SL, center, front, 7075 aluminum, black ano)
TKR5581 - Shock Tower (front, 7075, black ano, SCT.3/SL)
TKR5584 - Shock Tower (rear, 7075, black ano, SCT.3/SL)
TKR5730 - V2 Adj. Hinge Pin Brace Set (composite, EB/NB/ET/NT/SCT)
差速器的区别:
TKR5149X – Differential Cross Pins (composite, 3pcs)
TKR5614X – Differential Outdrives (SCT410, f/c/r, lightened)
避震系统的区别:
TKR6140 - Locking Shock Rod End and Spring Perch Set (EB/NB/ET/NT/SCT)
TKR6143 - Shock Boots (medium length, front, EB/NB/SCT, 2pcs)
TKR6144 - Shock Boots (long length, rear EB/NB/SCT, front ET/NT, 2pcs)
其他零配件的区别:
TKR1215 - M5 Locknuts (aluminum, flanged, serrated, black, 4pcs)
TKR1238 - Droop Adjustment Screws (M4x10mm, 8pcs)
TKR1605 - M3x10mm Set Screws (black, 10pcs)
TKR1609 - M3x3mm Set Screws (black, 10pcs)
TKRBB05134 – Ball Bearing (5x13x4, 4pcs)
TKRBB06135 – Ball Bearing (6x13x5, 4pcs)
鱼我要吃鱼 金牌 Fans 发消息
发表于 15-3-19 16:54:26 |显示全部楼层 来自: 中国江苏
关键是其价格
断桥de晓风 论坛元老 发消息
发表于 15-3-19 17:07:39 |显示全部楼层 来自: 中国山东泰安
价格呢?
鱼我要吃鱼 金牌 Fans 发消息
发表于 15-3-19 17:14:34 |显示全部楼层 来自: 中国江苏
官网标价399.99跟410一样的价格
断桥de晓风 论坛元老 发消息
发表于 15-3-19 17:27:55 |显示全部楼层 来自: 中国山东泰安
偷轻版本怎么觉得有点心里不踏实呢
偶000000 中级 Fans 发消息
发表于 15-3-19 17:45:14 来自手机 |显示全部楼层 来自: 中国广东
这个要多少米
韬涛  和老款的价格一样。  详情 回复 发表于 15-3-19 20:51
邪神的呼唤 论坛元老 发消息
发表于 15-3-19 20:41:59 |显示全部楼层 来自: 中国江苏连云港
想入48,怕断臂
韬涛  48.2不断的。48SL就不清楚了。  详情 回复 发表于 15-3-19 20:54
韬涛 金牌 Fans 发消息
发表于 15-3-19 20:51:50 |显示全部楼层 来自: 中国河南郑州
偶000000 发表于 15-3-19 17:45
这个要多少米
和老款的价格一样。
韬涛 金牌 Fans 发消息
发表于 15-3-19 20:54:13 |显示全部楼层 来自: 中国河南郑州
邪神的呼唤 发表于 15-3-19 20:41
想入48,怕断臂
48.2不断的。48SL就不清楚了。
邪神的呼唤  48和48.2哪里能区分呢?  详情 回复 发表于 15-3-19 21:12
