[产品信息] KKPIT1323 SERVO
查看: 4262|回复: 0| [复制链接]
发表于 14-12-31 11:11:05 |显示全部楼层 来自: 中国广东东莞
Dead band: 2μs
Working frequence: 1520μs / 330hz
Operating Voltage:  DC4.8~6.8 V
Motor: coreless motor
Operating Temperature Range: -10 to + 60C
Operating Speed (4.8V): 0.12sec/60°
Operating Speed (6V): 0.09sec/60°
Stall Torque (4.8V): 14.21 kg.cm (197.33oz/in)
Stall Torque 6V): 16.83kg.cm (233.72oz/in)
Potentiometer Drive: Direct Drive
Dimensions: 40.5X20.5 X 36mm /1.59X0.80X1.42in
Weight: 72.1 g (2.54oz)
Connector Wire Length: JR  265 mm (10.43in)
Bearing: 2BB
