本帖最后由 tommydai 于 14-9-29 22:15 编辑 官网刚刚公布了BD7 2015详细照片和介绍 ![]() Yokomo is introducing the BD7 2015 Black Series high-performance competition touring car kit for the 2015 racing season, the successor to the highly-popular and race-winning BD7 2014. YOKOMO向各位介绍基于2014年巨大成功和流行的BD7 2014后的又一高性能竞赛电动房车----BD7 2015 黑色版 研发者 海野的采访录像:http://v.youku.com/v_show/id_XNzkzNTk4ODUy.html?qq-pf-to=pcqq.c2c Stability and cornering speed are two important factors when it comes to racing. This is also true in the R/C touring car category. The BD7 2015 has been engineered to deliver those two contrasting but essential characteristics to assist you in achieving success not only in high-speed races of the modified class, but also for stock class racing where regulations restrict maximum speed. The performance potential the car possesses becomes a major advantage in gaining the upper hand. 稳定和在弯道中获得更高的车速是两个非常重要的制胜因素。这个在RC界是不可动摇的真理。 BD7 2015 也竭尽全力来实现这2个看似互相违背的原理。不单单在MODIFIED组别,更多的开始注重在STOCK组别来实现这2个特性。车架在这2个方面的发展潜力也是为什么可以胜出比赛的关键所在。 The Yokomo BD7 platform has pioneered the configuration that improves grip by reducing the rigidity of the bulkhead area. The BD7 2015 further evolves that trend setting concept by lowering the center-of-gravity with the bulkhead caps, and enabling variable adjustment of the front and rear grip balance by attaching or removing the newly-designed cross bulkhead. These features gives the new BD7 2015 much higher cornering speed, a level which is out of this dimension. YOKOMO BD7的研发平台已经在解决减少波箱刚性方面处于领先位置,BD7 2015 的进化就是通过降低上波箱的重心,通过安装或者不安装全新设计的波箱X型支架来调节前后抓地力的平衡,从而提供更高的弯中速度。 Furthermore, the newly-designed motor mount, battery holder and chassis contributes to the improved roll characteristics. Of particular importance is the newly-developed battery holder which affixes the battery in a way that does not disrupt the excellent torsion characteristics of the chassis, which allows nearly-equal left and right steering characteristics, leading to improved handling and reduced uneven wear of the tires. 全新设计的马达座,电池架和底板都是为了增加滚动。特别是全新设计的电池架,更是为了电池安装后,不影响车架的扭动特性,使得左弯和右弯可以更好的平衡,从而达到左右轮胎均衡磨损的情况。 The performance potential that the new BD7 2015 has acquired through continued technological innovation will no doubt make the BD7 2015 the ultimate competition kit and it will continue to lead the current touring car racing scene! Yokomo will lead you to victory! Specifications 1/10th-scale electric 4WD belt-driven touring car kit Newly-designed carbon double-deck chassis which actualizes ultimate maneuverability 全新设计碳纤维底板,提供无与伦比的操控性 Newly-designed motor mount which optimizes the torsion characteristics of the chassis 全新设计的马达座 Newly-designed front and rear bulkheads affixed by cross bulkheads which allows adjusting of the chassis roll freely 全新设计的前后波箱 Re-engineered battery holder and weight attachment methods prevents disruption of the chassis torsional characteristics leading to even left/right steering 重新设计的电池座,提供更好的重心分布 Newly-designed lightweight front spool joint 全新设计前头直轴 Newly-designed gear differential 全新设计差速 Support for wider range of gear ratio configurations, allowing comprehensive compatibility with various racing regulations, such as sport, stock and modified class racing 更宽广的齿比搭配范围,可以更好的适合SPORT\STOCK\MODIFIED组别 Lightweight molded graphite composite materials used in the suspension arms, front/rear hubs and knuckles 超硬轻量化的塑料件 Separate aluminum suspension mounts (front rear-side and rear front-side) 分体臂码 Front aluminum solid axle 前铝合金头直轴 Lightweight plastic cam belt tensioner 轻量化皮带松紧调节轮 Standard equipped with front/rear stabilizer 前后防倾杆为标配 Low-friction hard anodized shock cylinder which reduces the internal resistance of the shocks 低阻力硬化处理避震筒 Optional parts (sold separately) 另外可以选购的改装件(单独发售) Forward motor conversion which reduces stress to the rear tires 前置马达座 Aluminum chassis plates 铝合金底板 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() BD7 2015 专用配件: ![]() ![]() |
