pringles 终极 Fans 发消息
发表于 06-11-15 14:24:44 |显示全部楼层 来自: 中国广东广州
Improved XPS.2
-          8 maps instead of 6 for finer adjustments.
-          latest team maps are incorporated for all classes.
-          revised maps for new Storm Evolution 4.5t
-          motor with sintered magnet.
-          improved and more precise throttle control for all motors.
Modes
Changes from 2007 Edition over normal Matrix Evolution (factory defaults: grey shaded):
Mode.2 (XPS.2): contains 8 instead of 6 values
Mode.4 (Automatic Brake): more precisely adjustable in smaller increments. Revised maps for perfect operation with sintered- and bonded-magnets.
Mode 1 (AutoCell System):
Mode LED
Value 1
Value 2
Yellow
LiPo/NiMH
Automatic
4-7cell NiMH Racing Mode
Mode 2(XPS.2): Higher value means more overall power and aggressive throttle response
Mode LED
Value 1
Value 2
Value 3
Value 4
Red
Smooth Power: 1X
Smooth Power: 2X
Smooth Power: 3X
Smooth Power: 4X
Value 5
Value 6
Value
7
Value
8
Linear Power: 4X
Linear Power: 5X
Progressive Power: 5X
Aggressive Pwer: 6X
NOSRAM tips!
Following settings are the preferences of the NOSRAM Factory Team:
-    Touring Car: Bonded: 4-7 Sintered: 3-5
-    Off-Road 2wd + Truck: Bonded: 1-2 Sintered: 1
-    Off-Road 4wd: Bonded: 1-4 Sintered: 1-3
-    1/12: Bonded: 3-5 Sintered: 2-4
-    Brushed Modified TW: Profil: 2-4
-    Brushed Modified Off-Road: Profil: 1-3
-    Brushed Stock: Profil: 4-5
Mode 3:(Initial Brake) allows you to set a certain level of hand-brake-effect
Mode LED
Value 0
Yellow/Red
(alternate)
No Initial Brake
Value 1
Value 2
Value 3
Value 4
Value 5
Value 6
Going from lowest to highest inital brake setting
(value 1 = minimum / value 6 = maximum)
NOSRAM tips!
Good starting point for the brake is 80% (bonded) and 70% (sintered) on the radio for all classes. But make sure you do the radio-setup with all settings on the radio on 100%.
Mode 4: (Automatic Brake) allows you to set a slight braking action in neutral range
Mode LED
Value 0
Yellow/Red
(same time)
No
Value 1
Value 2
Value 3
Value 4
Value 5
Value 6
Going from lowest to highest automatic brake setting (value 1 = minimum / value 6 = maximum)
NOSRAM tips!
You achieve the same natural slowdown as a brushed motor with no autobrake when you set value 2/3 (for bonded magnet) or 0/1 (for sintered magnet).
Improved Push Brake
-          new efficient brake software, more control and lower motor-/speedo-temperature.
Improved Automatic Brake
-          more precisely adjustable in smaller increments.
-          revised brake maps for perfect operation with sintered- and bonded-magnets.
Internal-Temp-Check System
As a world-exclusive the 2007 Edition allows you to read-out the maximum internal temperature that the speedo reached. To save it to the memory you have to briefly apply brakes after the run before you turn the switch off. You can conveniently read-out the temperature back in the pits since it remains stored until you turn it on the next time regularly (which will reset the memory).
This new feature allows you to accurately check if all is running well or if youre close to shutdown already!
Launch Control
Launch Control: Well known and famous from our brushed speedos! Now also available for brushless. The launch control allows rocket like starts. After activation it gives you more power one time for the start (this feature is only recommended to be used with touring cars on high traction surfaces!).
Order No.
Item
90700
MATRIX Evolution 2007 Edition Brushless + Brushed
发表于 06-11-15 14:24:59 |显示全部楼层 来自: 中国广东广州
NOSRAM novelties - November 06 - 13.11.2006
+++ These novelties are available in your local hobby shop during the next days already +++
We are very proud to send you an exclusive preview over the very latest NOSRAM novelties:
The superior Brushless technology is rapidly growing all over the world now and the NOSRAM Brushless System is the leading technology featuring outstanding power and extra smooth throttle response!
NOSRAM is now taking this successful brushless technology to the next step by releasing the MATRIX EVOLUTION 2007 Edition speed control! The new MATRIX EVOLUTION 2007 Edition is a completely updated speed control with improved soft- and hardware, developed for ultimate racing performance and unbeatable track handling!
The MATRIX EVOLUTION 2007 Edition Brushless+Brushed is now the highest performance speed control of the NOSRAM Brushless range.
The MATRIX EVOLUTION 2007 Edition Brushless+Brushed Improved Soft- and Hardware!!
发表于 06-11-15 16:30:38 |显示全部楼层 来自: 中国上海
俺看不懂鸟文。。
忆の伤 论坛元老 发消息
发表于 06-11-15 18:50:03 |显示全部楼层 来自: 中国北京
我怎麽看招眼熟............
唐乾钧 超级元老 发消息
发表于 06-11-15 23:07:17 |显示全部楼层 来自: 美国
基本copy lrp的外观设计.
鉴定完毕
遥控大猫 超级元老 发消息
发表于 06-11-16 02:29:16 |显示全部楼层 来自: 中国北京
LRP就是给Nosram做OEM的 不过据说Nosram比LRP要平一些~原因是.......
