:em08: Front:
| | Rear:
Yokomo is sat lower in these shots, but you can see the rear suspension is same height even though the car is a few mm lower.
| | Anim showing different weight distribution.
Yokomo is longer than the XX4 by a couple of mm or so.
Front
All cars only have cells in, though the predator tends to sit lower than the other two when fully loaded.
Not much i can say about these comparisons as the cars are so different. Generally the preds diffs look higher placed, but the overall lower CoG is very evident.
Inner camber link is a lot lower and longer on the xx4.
| | Front
Zx5 shocks sit even higher than the xx4, and ofcourse much-much higher than the X10.
Camber link is similar height but further inboard.
| | Rear
apart from the diffs, the suspension is looking fairly similar.
| | Rear
Rear diff height is fairly similar here, inner camber link is a lot higher.
Front
On all photos I tried to keep the Diffs around the same height.
On all photos its clear the diff in the XX4 is mounted lower than the other cars so for a given diff height there is more ground clearance.
| | Front
XXX4g+ diff sits much higher than the XX4 because of the large diameter pulley.
| | Rear
| | Rear
