holyfactory 元老 Fans 发消息
发表于 06-10-1 07:06:55 |显示全部楼层 来自: 美国
React R/C Controller:
Radio Type: digital spread spectrum 2.4 GHz
Radio Mode: frequency hopping spread spectrum (FHDSS) & direct sequence spread spectrum (DSSS)
Game Mode: Though the USB cable to PC seen as game controller / joystick
Range: 2000ft.
Power Output: 100mW FHDSS / 10mW DSSS
Frame Rate: 100 frames per second FHDSS / 50 frames in DSSS
Total Latency: 5 millisecond max, 2ms typical
Weight (w/Batteries): approximately 18 oz.
Servo Channels: 4
Four cell re-chargeable battery:
Model Memory: 40 named
Controller Battery: Voltage Monitor: graphic and real-time
Receiver Battery: Voltage Monitor: graphic and real-time
Timers: operation and lap timers
Trims: adjustable trims and sub-trims
Controls: dual rate, endpoints, exponential, advanced brake mixing and servo speed adjust on all channels
Anti-Lock: brake anti-lock with adjustable trigger, cycle, delay, depth, and steering trigger
Idle Up: yes
Tactile Alarm: programmable vibrator
Display: Graphic LCD
Resolution: 128 x 96 pixels
Auto Modes: auto display and display only
Presets: failsafe and auto start
Telemetry: real time speed, temperature, and battery supported (sensors purchased separately)
Servos Supported: any combination of analog and digital
PC Connectivity: USB serial for charging, customization, analysis and updates
Antenna: Built in
Architecture: software upgradeable
carbk 金牌 Fans 发消息
发表于 06-10-1 08:23:07 |显示全部楼层 来自: 中国河北石家庄
不知什么时候到国内,价格一定不菲啊.
发表于 06-10-1 08:59:47 |显示全部楼层 来自: 中国湖南长沙
这个设计的审美观真是...........
看屏幕就可以把脖子累得要死
发表于 06-10-5 09:24:32 |显示全部楼层 来自: 美国
原帖由 slaly 于 2006-10-3 03:35 PM 发表
给人感觉不是很专业
功能几乎一样,使银幕小一点和没有WAV播放而已。
