[产品信息] H-K1 World Champion Meen Version
查看: 1477|回复: 0| [复制链接]
发表于 14-3-18 09:30:47 |显示全部楼层 来自: 中国香港
1/10 Seale Super Luxury Full Option
4WD GP Touring Car
Special Features :
1. Dark blue colour for aluminium bulk heads.
2. Steering servo to be mounted on to the main chassis OR to the upper deck.
3. New alum centre mount.
4. New high efficency brake disk is included as standard.
5. Rear body height adjust post is included as standard.
6. Front anti-roll bar system is included a standard.
7. Alum. full set steering servo horn.
8. Alum. full set throttle servo horn.
9. Full set rear anti-roll bar.
10.Full set spur gear.
11.(a) Front pulleys 27T-19T with 201mm bando plastic belt
(b) Side pulleys 25T-18T with 390mm bando plastic belt
(c) Rear pulleys 20T-18T with 177mm bando plastic belt
http://www.km-rc.com/
