[产品信息] EVO2-192B 5mm Bando Front Belt
查看: 1323|回复: 0| [复制链接]
发表于 14-2-27 09:26:17 |显示全部楼层 来自: 中国香港
H-K1 Optional Parts
Special Features :
1. New design plastic front pulley 24T with stronger edge on the screw side
   and suitable to use with stronger 5mm wide front belt.
2. The new front belt with 5mm wide give much better life time.
3. Three new item must use together to give much better performance
   and direct fit onto the current H-K1.
http://kmrcshop.com/products/EVO ... ndo-Front-Belt.html
http://www.km-rc.com/
