这东西出来很久了吧 AM Conversion Module for 3PK More flexibility for 3PK owners! This ingenious module converts the Futaba 3PK computerized 3-channel FM radio to operate on AM 27MHz band. Converting to AM allows the 3PK to be used with Mini-Z Racers, Ready-To-Run models—any car, truck or boat that would normally be controlled with an AM system. Enables drivers to take advantage of the 3PK's sophisticated computer functions, including throttle and steering adjustments, exponential, EPA and multiple model memory. Designed specifically for the 3PK; will not work with other radio systems. |
