刚刚在12仔世界赛获得冠军的David选用的这台充电机.充电放电功能都有. 10A & 35A Coolflex current conditions the pack for maximum power and runtime, while keeping it cool. Cool means longer lifetime, less stress! - Adjustable cut-off voltage of 0.8 to 1.1 Volt. Always the right settings for every pack! - the large red-backlight display gives you all the information you ever need: total runtime, actual voltage, average voltage, total energy, capacity and internal resistance. Clearly visible even in direct sunlight! - the memory module in the device holds the data of the previous discharge, so this can be readout as often as you like. - CC/CV/CP discharge mode for best performance: Constant Current (accurate), Constant Voltage (maintenance), Constant Power (fast). For racing packs, Micro 1/18 packs and receiver/transmitter packs! |
