![]() ![]() Yeah Racing Aluminum Rear Suspension Arm Set For 3Racing Sakura D3 CS Sport #SD3-002PK Description: This is a Yeah Racing Aluminum Rear Suspension Arm Set For 3Racing Sakura D3 CS Sport. Yeah Racing carefully designed the suspension to be strong yet light-weighted for drifting. Flex has been minimized by precise CNC process, hence the weight shift will be smoother benefiting from the smoother suspension movements. YR highly recommend to use this part with #SD3-001 for the highest possible performance improvement. ![]() ![]() ![]() *Photos for reference only. Feature: For: 3Racing Sakura D3 CS Sport Material: Aluminum Color: Pink Include: Aluminum Rear Suspension Arm (1 pair) M3 x 10mm Set Screw (2 pcs) M3 Nut (2 pcs) Manual (1 pc) Manual: ![]() 密切留意YEAH RACING专区,为你提供最新资讯! 更多YEAH RACING产品,请关注电波淘宝:http://item.taobao.com/item.htm?spm=0.0.0.0.wAe6n7&id=36066786833 |
