本帖最后由 Yeahracing 于 13-11-13 10:44 编辑 ![]() ![]() ![]() ![]() ![]() ![]() Yeah Racing Aluminum Set Up Wheels for 1:10 RC Touring Car (BU) #YT-0069BU Description: These are the Yeah Racing Aluminum Mini Set Up Wheels for 1/10 touring cars. 25% lighter than standard set up wheels! It eliminates errors from using standard rubber or foam tires. A perfect set up tool for precise, repeatable set-up adjustment and tweak correction! ![]() When setting up the touring car, the rubber tires usually give non precise measurements. As the rubber tires are not perfectly rounded, one tire maybe lifted than the other tire, even though the touring car is not tweaked ![]() With this tool in hands, it will allow you to check for tweak precisely! ![]() * Photos for reference only. Feature: For: 1/10 Touring Car Material: Aluminum Color: Blue Specification: Diameter: approx. 65mm Weight: 10g each Include: Yeah Racing Aluminum Mini Set Up Wheels (4 pcs) Recommend Items: Yeah Racing #YT-0056 3 in 1 Camber Gauge Yeah Racing #YT-0055 2 in 1 Ride Height & Droop Gauge Yeah Racing #YT-0068 Ultra Fine 2 in 1 Ride Height & Droop Gauga 密切留意YEAH RACING专区,为你提供最新资讯! 更多YEAH RACING产品,请关注电波淘宝:http://item.taobao.com/item.htm?spm=0.0.0.0.N05coo&id=36019659181 |
