![]() ![]() ![]() ![]() ![]() ![]() Yeah Racing Aluminum Ball End Remover For 4 4.8 5 6mm Ball End Pink #YT-0135PK Description: A perfect tool for removing stubborn ball ends with minimum efforts as well as wears on the ball ends. With this tool, you will need only a second to remove ball ends which make it a life saver when you are need a quick fix on the track-side. A must have item for any racers. Feature: For: 4mm / 4.8mm / 5mm / 6mm Ball End Material: Aluminum Color: Pink Specification: Length: 80mm Width: 150mm Height: 50mm Weight: 10g Include: Yeah Racing Aluminum Ball End Remover (1 pc) 密切留意YEAH RACING专区,为你提供最新资讯! 更多YEAH RACING产品,请关注电波淘宝:http://item.taobao.com/item.htm?spm=0.0.0.0.op7lud&id=36020625587 |
