本帖最后由 Yeahracing 于 13-11-12 17:00 编辑 ![]() ![]() ![]() ![]() ![]() Yeah Racing Aluminum Conversion Kit Ultimate Version Blue For Tamiya TT-01/ TT-01E #CK-TT01/EV2BU 更新了避震组,原来旧套装所配避震货号为DP-1002,现新避震为DSC-0050系列分蓝,红,紫三色可选. Description: Yeah Racing TT01 conversion kit upgrade version will significantly improve the balance and speed of the Tamiya TT-01. Compared to the out of the box version, it improves TT01’s stability, allowing it to run smoother on different surfaces. Aluminum Main Drive Shaft replaces the standard molded plastic drive shaft for extra power handling; it also offers more predictable acceleration. The aluminum upper arm set is equipped with adjustable camber which enhances the response of Tamiya TT01 and allows for sharp turns. Different damper can also be selected to fit your own driving style. All in all, Yeah Racing TT01 conversion kit (upgrade version) includes everything you need to upgrade from the original TT01 to a competitive RC car. ![]() ![]() ![]() 密切留意YEAH RACING专区,为你提供最新资讯! 更多YEAH RACING产品,请关注电波淘宝: http://item.taobao.com/item.htm? ... a4V&id=35837583737& |
