好消息! YEAH RACING 推出TT02全车金属升级件套装 #CK-TT02BU,敬请大家关注! ![]() ![]() ![]() Yeah Racing Aluminum Conversion Kit For Tamiya TT02 #CK-TT02BU Description: This is a Yeah Racing Aluminum Conversion Kit For Tamiya TT02. This kit consists everything you need to upgrade your TT02 and unleash its full potential! Despite the stock Tamiya TT02 use an extensive amount of plastic parts, Yeah Racing has found that the TT02 is actually a touring kit that has heaps of potential to offer. Yeah Racing exquisitely use the premium quality of material coupled with precise CNC cutting to manufacture all the parts in the conversion kit. The result is an astonishing performance and durability upgrade due to the minimum friction and flex between moving parts and joints. A Premium grade of bearings is also included to replace all the plastic bearings on the stock TT02 for exceptional driving smoothness and power efficiency. This conversion kit also offer an extensive adjust-ability for your TT02 to race under different conditions and tailor fit your driving style. For instance, dampers is fully adjustable and comes with 5 set of spring with different stiffness. Both front and rear upper arms are adjustable for camber angels. A Solid Axle is also included change the driving characteristic. These adjust-ability has make this conversion kit very flexible to serve with any kind of settings and motors. This is the ultimate upgrade kit for people who are sick of seeing the plastic parts breaks again and those who wanted to unleash your TT02 to its full potential. ![]() ![]() ![]() ![]() ![]() 密切留意YEAH RACING专区,为你提供最新资讯! 更多YEAH RACING产品,请关注电波淘宝: http://item.taobao.com/item.htm? ... 71TO&id=35841260739 |
