代码来了,接收:
#include "51Duino.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define uchar unsigned char
#define uint unsigned int
sbit IN = P1^6;//信号输入端口
sbit I1 = P1^0;
sbit I2 = P1^1;
sbit I3 = P1^2;
sbit I4 = P1^3;
sbit LED = P0^1;
void setup()
IN = 1;
unsigned char receive(void);
char cTimes = 0;
unsigned char loop()
char cToken, cOldToken;
cToken = receive();
if (cToken != 0)
if (cToken == cOldToken)
cTimes ++;
if (cTimes > 5)
P1 = cToken;
Send(cToken);
cTimes = 0;
else
cOldToken = cToken;
cTimes = 0;
return TRUE;
void delay(unsigned char t)//延时程序
unsigned char n;
for(; t > 0; t--)
for(n = 40; n > 0; n--);
接收协议:接收函数先寻找前导命令,探测到前导命令之后进入数据接收模式,
否则返回0(表示接收失败或者没发现可用信号),接受成功之后返回收到的数
据
unsigned char ReadBit()
unsigned char i = 0;
if (IN == 1) i++;
if (IN == 1) i++;
if (IN == 1) i++;
return i > 2 ? 1 : 0;
unsigned char receive(void)//接收处理函数
unsigned char guid = 0, result[16], i, key = 0, res = 0, t, time = 0;
while(1)//捕获前导命令
while(ReadBit() == 1)
t++;
if(t >= 27)
delay(100);
return 0;
}//防止错误数据导致的死循环
if(t >= 18 && t < 26) // 典型值: 19-21
// NumericSendString("\r\n\r\nt = ", t);
key++;
time = 0;
if(key > 3)
break;
} //获得前导命令跳出循环,清除计时信号
else if(time > 100)
delay(100);
LED = !LED;
return 0;
} //长0,错误信号返回0
else
t = 0;
time++;
}//计时垒加,清除t
t = 0;
time = 0;
for(i = 1; i <= 16; )
t++;
if(t >= 27)
delay(100);
return 0;
}//防止错误数据导致的死循环
// NumericSendString("\r\nt = ", t);
t = 0;
i = 1;
time = 0;
}//去除多余的前导命令
else if(t >= 7 && t < 17) // 典型值: 11-14
result[i - 1] = 1;
i++;
time = 0;
}//捕获数据1
else if(t > 0 && t < 7) // 典型值: 1-6
result[i - 1] = 0;
i++;
time = 0;
}//捕获数据0
if(time > 100)
return 0; //消除长0的干扰确保数据正确
t = 0; //清零
time++;//计时
if(((result[0] + result[8]) == 1) &&
((result[1] + result[9]) == 1) &&
((result[2] + result[10]) == 1) &&
((result[3] + result[11]) == 1) &&
((result[4] + result[12]) == 1) &&
((result[5] + result[13]) == 1) &&
((result[6] + result[14]) == 1) &&
((result[7] + result[15]) == 1))//判断校验码
for(i = 0; i < 8; i++)
res += result[7 - i] << i;
}//将结果转换为十进制数据
return res;//返回得到的结果
发射:
#include "STC315TX.h"
unsigned char nTimes = 0;
void setup()
unsigned char nFlag;
LED1 = 1;
while ((nPointReadPos != nPointWritePos) && (nPointReadPos != ((nPointWritePos - 1 + LEN_SIZE) % LEN_SIZE)))
LED1 = 0;
nFlag = cString[nPointReadPos++];
nPointReadPos %= LEN_SIZE;
SendByte(nFlag);
if (nTimes <= 1 && nTimes >= 0)
nTimes ++;
LED2 = 1;
else if (nTimes >= 2 && nTimes <= 3)
nTimes ++;
LED2 = 0;
else
nTimes = 0;
LED2 = 1;
LED1 = 1;
LED2 = 1;
return TRUE;
stc315tx.h 文件:
#ifndef STC315TX_H
#define STC315TX_H
sbit OUT = P1^0; // 输出端口
sbit LED1 = P1^1; // 红色 LED
sbit LED2 = P1^2; // 蓝色 LED
发送协议:
发送断发送数据时先发送6个前导命令(脉宽为650us左右的方波),
接着传输数据,先发送数据的高位(“1”为脉宽450us左右的高电平方波,
“0”为脉宽100us左右的方波),每个数据发送三次,每发送完一次之后发送
一个同步信号(同步信号脉宽和前导命令一样),发送完后输出低电平。
unsigned char jud=1;
void delay(unsigned char t)//延时函数
unsigned char n;
for(;t>0;t--)
for(n=50;n>0;n--);
void guid()//前导命令,同步信号
OUT=1;
delay(6);//脉宽为 500us, 作为前导命令. (接收: 高460us)
OUT=0;
delay(6);//脉宽为 550us, 作为前导命令. (接收: 低540us)
void send(bit key)//位数据发送程序,发送一个1/0
if(key==1)//发送1
OUT=1;delay(4); // 脉宽为 335us (接收: 高300us)
OUT=0;delay(1); // 脉宽为 100us (接收: 低135us)
else //发送0
OUT=1;delay(1); // 脉宽为 90us (接收: 高 65us)
OUT=0;delay(4); // 脉宽为 345us (接收: 低370us)
void sendBitNot(bit key)//位数据发送程序,发送一个1/0
if(key==0)//发送1
else //发送0
void SendByte(unsigned char tcToken)//发送数据
unsigned char nFlag, nBit, temp;
for(nFlag = 0; nFlag < 6; nFlag++)
guid();//发送前导命令
LED1 = 1;
for(nFlag = 0; nFlag < 3; nFlag++) //每个数据发送三次
temp = tcToken;
for(nBit = 0; nBit < 8; nBit++)//发送一个比特的数据
temp <<= 1;//右移取得高位数据
send(CY);//发送高位数据
temp = tcToken;
sendBitNot(CY);//发送高位数据
guid(); //发送同步信号(非常重要!)
LED1 = 0;
void SendStr(char *s)
while(*s) SendByte(*s++);
#endif |
