23319710 论坛元老 发消息
发表于 13-6-27 22:31:29 |显示全部楼层 来自: 中国河北石家庄
Overall Length                 :        328mm
Overall Width        Front width        :        185-200mm
        Rear width        :        185-200mm
Wheelbase length:                 :        270mm
Weigh        (fully equipped with long
pack LiPo 7.4V battery):         :        1165g
        Chassis only        :        320g
Specification may be subject to change without notice
Similar to full size F1 cars, the SP-1 F1 1/10th scale chassis utilizes a high quality 3mm streamlined carbon fiber lower chassis, a 2mm upper deck, and lightweight 7075 aircraft grade aluminum. Chassis stiffness can also be fine tuned using 6 chassis spacers depending on track conditions. Aluminum components, such as the rear pod and center shock are anodized with a stealth black finish. The SP-1 F1 1/10th scale chassis also allows different lipo battery positions and configurations. The SP-1 can fit regular size 2 cells lipo battery or the shorty 2 cell lipo packs. The SP-1 F1 1/10th scale chassis represents Speed Passion's high quality standards on and off the track as racers can put the chassis' craftsmanship and attention to detail on display. SP-1_F1_r041.jpg
The SP-1 F1 1/10th scale chassis was designed with a precision balanced rear motor pod. The rear motor pod design ensures allow precise control and balance when entering and exiting corners which allows drivers to easily carve the fastest line around the track. The rear differential utilizes high quality pressure plates along with 18 chrome differential balls for smooth differential action.
The SP-1 F1 1/10th scale chassis suspension is designed with an innovative dual bellcrank steering system that allows the Ackerman to be fine tuned for precision control. The suspension also allows for infinite camber adjustment and 5°and 10°caster blocks for any type of track condition, indoor or outdoor, carpet or asphalt. Optional front springs can be quickly changed as track conditions change. The adjustable track width (front and rear) allows the SP-1 F1 1/10th scale chassis to adapt to the various F1 racing specification throughout the world. The track width can be adjusted to 190mm and lower with rubber tires and can be adjusted to 200mm when using foam tires. With optional parts, the track width can be adjusted the F1 world spec of 185mm. The SP-1 F1 1/10th scale chassis can adapt to various aftermarket foam or rubber tires.
The SP-1 F1 1/10th scale chassis is designed with a centrally located, large volume shock that is attached to a carbon fiber mounting plate. The result of is stability and traction on high speed track sections and total control in small, tight, sections. These characteristics are not easily found on today's crop of F1 chassis'.
High quality option parts for the SP-1 F1 1/10th scale chassis include a full aluminum motor pod, various shores of foam and rubber tires, aluminum preset camber blocks ranging from 0°to -2.5°, and aluminum caster blocks in multiple angles.
Our Chassis will fit many type of F1 ranging from 185-200mm with optional parts.
小顺19891123 RC 新手 发消息
发表于 13-7-13 16:40:58 |显示全部楼层 来自: 中国辽宁大连
不错不错。。。。。。。。。。。不错不错。。。。。。。。。。。不错不错。。。。。。。。。。。不错不错。。。。。。。。。。。不错不错。。。。。。。。。。。不错不错。。。。。。。。。。。不错不错。。。。。。。。。。。
maxugood 元老 Fans 发消息
发表于 13-8-30 19:35:13 |显示全部楼层 来自: 中国广西百色
好漂亮的车车哟
发表于 13-8-30 23:58:49 |显示全部楼层 来自: 中国山东济南
