354015 Alu Center Diff Mounting Plate Set (2) Aluminum center diff mounting plate set designed to increase rigidity and strength. CNC-machined from highest-grade aluminum. Like most main alloy components on the XB8 and XB8-TQ, this plate set is finished in XRAY stylish black with trademark silver edging. Includes composite bushings which eliminates vibration and excessive wear of the diff outdrives. (click to enlarge) The alu stands are split which allows very easy access to the differential. |
