council 长老 Fans 发消息
发表于 06-5-29 06:54:10 |显示全部楼层 来自: 英国
Today’s high capacity Ni-MH batteries from Intellect and GP require dischargers that stop the discharge process at around .90 volt per cell for maximum performance on the next charge cycle. The packs produce more voltage and better run times, when discharged to this level, and it mimics the usable battery levels seen on the race track.
Feature
Each cell will be discharged to .9, volts per cell. When the voltage reaches .9 the LED for that cell will go out. The lights will go out one by one, until the pack is fully discharged. When all the lights are out you can store your pack, until the next race. Packs may be left in the D-90 with no harm like other discharge boards, which will continue to discharge down to zero voltage.
