● 950 super-high torque motor adoption with room. ● The lei was downed by steel pinion &M3 belt, and a proper rotation and the torque were achieved in the setter work. ● All aluminumCNC out frame. wick blur is none at all. ● The large diameter housing with the ball bearing is adopted, the friction is suppressed, the shaft axis is held surely, and high durability is achieved. ● Hub assistant for touring ● The use power supply corresponds to 7, 2V, and stabilizing supply 12V of reserves. ● Size: L167xW93xH130 |
