council 长老 Fans 发消息
发表于 06-5-17 16:17:02 |显示全部楼层 来自: 英国
Dual-Purpose Aluminum Wrench
5.5mm & 8mm
After the release of the 17mm and 23mm wheel wrenches, customers have been demanding more wrenches by Pro-Line. The new Dual-Purpose wrench fills a gap in the market by offering two of today’s most popular size nut drivers for 1:8 Buggy, 1:8 Truck, and Monster truck chassis-an 8mm nut driver on one side and a 5.5 mm on the other.
The dual-purpose wrench is made from 6061 aircraft grade aluminum. Each side of the driver has an inner backstop to hold the nut secure. Blue, aluminum anodizing completes the driver with a bling-bling finish combined with a pad-printed Pro-Line logo.
Features:
· 5mm on one side, 8mm on the other
· Made from 6061 aluminum
· Stylish pad printed Pro-Line logo
· Replace two tools in your tool box for one
Dual-Purpose Aluminum Wrench - 5.5mm & 8mm
Part #6043-00
council 长老 Fans 发消息
发表于 06-5-17 16:17:47 |显示全部楼层 来自: 英国
Pro-Line Pit Mat
Do you ever wonder what to do with the old pit towel after you have used it two times because it just gets thrashed by motor cleaner, grease, and whatever else you throw at it? Well, throw it in the trash because Pro-Line has your answer. Introducing an economical, long-lasting, and pit appearance enhancing pit mat -The Pro-Line Pit Mat.
The Pro-Line Pit Mat is backed with 1/16” high-density foam, is coated with a durable, long-lasting vinyl coating over the Pro-Line graphic, and is cost friendly. No more do you have to worry about throwing your pit towel away with the Pro-Line Pit Mat. Simply place on your pit, it’s anti-skid foam backing construction does not need to be taped down to stay centered in your pit, and you’re ready to go.
Pro-Line – Making you, your car, and now your pit look good all at the same time.
Features:
· 17” x 26” is size
· Foam backing for a skid resistant pit mat
· Long lasting and durable
Pro-Line Pit Mat
Part #9908-00
