council 长老 Fans 发消息
发表于 06-5-14 03:58:51 |显示全部楼层 来自: 英国
Apogee 2-Cell 2200 mAh Battery Pack w/Voltage Port
Item#:
2S1P2200HP
Price/ea.
$61.99
Pack Specifications:
Capacity: 2200 mAh
Dimensions: 16mm Thick x 37mm Wide x 100mm Long
Weight: 115 Grams (4.10 Oz)
14 Gauge Silicon Wire Leads
Operating Specifications:
Maximum Charged Voltage: 8.4V
Minimum Discharged Voltage: 6.0V
Maximum Charge Amperage: 2.2A (1C)
Maximum Continuous Discharge Amperage: 44A (20C)
Maximum Operating Temperature: 60C (140F)
Connector NOT Included.
Replaces the following 6-cell packs:
CBP2000
GP2200
Other Standard 4/5 Sub-C or Full Sub-C Ni-Cd/Mh Round Cells of 2200 mAh Capacity
Known 1/18th Scale Car/Truck Chassis Compatibility:
Associated RC18 Series (Buggy, Truck, Monster Truck)
X-Ray M18T
X-Ray M18
Trinity Itsy Bitsy Spyder
May fit other vehicles. Check battery compartment and compare against listed pack dimensions.
__________________________________________________ ___________
Apogee 3-Cell 3800 mAh Li-Mn 20C Battery Pack
Item#:
3S1P3800MN
Price/ea.
$149.99
Capacity: 3800 mAh
Dimensions: 27mm (1-1/16") Thick x 42mm (1-11/16") Wide x 139mm (5-5/8") Long
Weight: 350 Grams (12.5 Oz)
13 Gauge Silicon Wire Leads
Maximum Charged Voltage: 12.6V
Minimum Discharged Voltage: 9.0V
Maximum Charge Amperage: 3.8A (1C)
Maximum Continuous Discharge Amperage: 76A (20C)
Tamiya type connector included
Also available, not shown: 2S1P LiPo
Name:
Apogee 2-Cell 3800 mAh Li-Mn 20C Battery Pack
Item#:
2S1P3800MN
Price/ea.
$99.99
Capacity: 3800 mAh
Dimensions: 19mm (3/4") Thick x 42mm (1-11/16") Wide x 139mm (5-5/8") Long
Weight: 236 Grams (8.35 Oz)
Tamiya type connector included.
