发表于 13-4-1 14:41:09 |显示全部楼层 来自: 中国广东广州
Details:
Special features:
- 32 Bit Mcu
- Powerful Heat Sink
- Advantage Synchronous Rectification    Technology
- USB Charging Port 5V/1A
- Software Upgrade Available
- Digital Power
- Discharge@ Energy Transfer Mode.  max. 1000W
- Balance Current Up To 1A
- High rate charge
- Touch screen
- Intelligent UI
DC  Input voltage range                     DC 11.0V~32.0V
Charge current range                         0.1A~40.0A
Discharge current range                     0.1A~40.0A
Charge power limited                          Input<24V:500W / Input>24V:1000W
Discharge power limited                     max.120W(max.5A)
Energy transfer discharge                  max.1000W
Balance  current                                 1.0A
Balance tolerance                              ±0.01V
NiCd/NiMH battery cell count             1~22cells
Lithium battery types                         Li-Po, Li-ion,Li-Fe
Lithium battery cell count                  1~8series
Pb battery voltage                             2V~32V
Digital Power                                     3V~36V
Operation system                               Graphical display
Weight                                               1520g
Dimensions                                         148*167*78mm
老婆是胖妞 高级 Fans 发消息
发表于 13-4-5 23:30:47 |显示全部楼层 来自: 中国贵州铜仁
最恶心这些发英文说明的!!完全是迷茫的!!
