RB新产品Tuned Pipe
查看: 1922|回复: 2| [复制链接]
council 长老 Fans 发消息
发表于 06-5-4 10:48:10 |显示全部楼层 来自: 英国
Available since: 2006/05/03
The new Revo 2 chambers tuned pipe has been designed and tested to provide low noise and increase wider power band. By increasing the bottom power and smoothing the acceleration, this pipe insures massive power for incredible wheeling! This pipe fit the original header from the TM523 and TM323.
council 长老 Fans 发消息
发表于 06-5-4 10:48:54 |显示全部楼层 来自: 英国
Tuned pipe IN-LINE 2045 polished
Available since: 2006/04/27
The RB Concept 063 is the most famous off Road pipe of the world: it's well known for the perfect balance between smooth power, low consumption and high RPM. Thanks to months of test RB is proud to introduce the most advanced 3 chambers off Road pipe the RB 2045P. Following the 3 chambers rules, this pipes provide at least the same top speed, but the low RPM and middle range power and the running time has been increased. Manufacturing with a new technology and thick material, this pipe has been reinforced for longer life and consistant performances.
三藏 超级元老 发消息
发表于 06-5-4 20:04:14 |显示全部楼层 来自: 中国重庆
还是抛光的漂亮啊!
