V one RRR 又出EVO版了
查看: 2294|回复: 9| [复制链接]
发表于 06-4-29 15:23:35 |显示全部楼层 来自: 中国北京
珊瑚海 论坛元老 发消息
发表于 06-4-29 18:31:33 |显示全部楼层 来自: 中国北京
EVO版是有引擎的版本嘛
克克 终极 Fans 发消息
发表于 06-4-29 19:57:32 |显示全部楼层 来自: 中国上海
这个跟macau-rc兄之前发的是一样的
http://bbs.rcfans.com/viewthread.php?tid=54682&extra=page%3D1
尼欧 超级元老 发消息
发表于 06-4-29 21:43:49 |显示全部楼层 来自: 中国浙江宁波
京商更新的速度真够快的
克克 终极 Fans 发消息
发表于 06-4-29 21:50:59 |显示全部楼层 来自: 中国上海
这是一些讲解VoneRRR Evo的改进
The belt drive 4WD touring car which controls 2004 IFMAR1/10GP touring car world championship furthermore maturing. Maintenance characteristic for encounter furthermore improvement e.g., with simple procedure removal and re-installation of the main shaft is made possible. As a vertical ranging throttle servo layout improvement maintenance characteristic. Adopting the mechanic plate of new layout. Fully loading the idea which is useful with encounter e.g., gauge function of the left and right position of a vessel's helm can be given by meat pulling out form and angle. To modify the part form above the rear bulkhead, selection of the upper arm pivot from the former 2 places in 5 places. From also the setting which decreases camber rate of change is possible. The brake rotor of the both sides grinding finish, promising preeminent damping force and the highest braking feeling with adoption of the teflon brake pad. With modification of constitution of aluminum brake hub adoption and the brake rotor and the pulley actualizing the damping force maintenance which does not change from opening of race/lace to goal. To take a second look the gear and the material etc. of the main shaft, substantial improvement the durability of drive type. Adopting the inside diameter 13 Φ damper springs of new rate, setting degree of freedom improvement. 2nd gear A/T standard equipment.
The first champion of the world machine which it should commemorate, achieving further maturing! Because it became the champion of the world, saying, it does not loosen the hand of development. True 摯 attitude only of such a capital trade, evolved the GP touring car world championship first champion machine. Just capital trade is thick not to spare the know-how whose is thrown the result which "V-ONE RRR Evo. It has breathed "in every nook and cranny. From it does again to stare the section from the point of view which rule is made encounter, structure and layout, furthermore even in the material prejudice being thorough. Durability and maintenance characteristic above the champion of the world machine, everything of setting corresponding power was learned. The machine which is chosen because very this wins. The design which stares the world, offers best speed to アナタ.
holyfactory 元老 Fans 发消息
发表于 06-4-30 02:58:30 |显示全部楼层 来自: 美国
骗钱之作,
RCPhil 论坛元老 发消息
发表于 06-4-30 08:23:15 |显示全部楼层 来自: 英国
原帖由 尼欧 于 2006-4-29 21:43 发表
京商更新的速度真够快的
为了赚钱当然要快
克克 终极 Fans 发消息
发表于 06-5-1 01:41:45 |显示全部楼层 来自: 中国上海
回复 #7 RCPhil 的帖子
这些都是小日本找机会赚我们的钱啊。
council 长老 Fans 发消息
发表于 06-5-1 01:54:21 |显示全部楼层 来自: 英国
原帖由 克克 于 2006-5-1 01:41 发表
这些都是小日本找机会赚我们的钱啊。
别带太多政治色彩..客观评价产品才是道理
克克 终极 Fans 发消息
发表于 06-5-1 08:42:30 |显示全部楼层 来自: 中国上海
原帖由 council 于 2006-5-1 01:54 发表
一点都没有政治色彩哦。希望别会错意。我得意识是说,日本品牌一向都是更新很快的。不像欧美产品更新很慢的
