发表于 13-1-23 14:48:20 |显示全部楼层 来自: 中国广东深圳
XQ-POWER XQ-S40系列高质数码舵机详细舵机参数!
1,XQ-S4013D 13KG高质数码舵机详细规格
XQ-S4013D图片:
型号:XQ-S4013D
品牌:XQ-POWER
Name:6V13kg-cm Digital Servo
Weight:56g ±0.2(1.97oz)
Gear type:Titanium Gear
Speed:0.11sec/60º at (6V)
      0.13 sec/60º at (4.8V)
Torque:12.8kg.cm.at(6V)
      12kg.cm.at(4.8V)
Titanium Gear;Waterproof; Plastic case, resist heat and corrosion; Aluminium middle hull, easy to eliminate heat;Adopt high quality coreless motor.
2,XQ-S4016D 16KG高质数码舵机详细规格
XQ-S4016D图片:
型号:XQ-S4016D
品牌:XQ-POWER
Name:6V16kg-cm Digital Servo;
Size :A:40.2mm B:20.1mm C:38.8mm D:48.0mm E:10mm;
Weight:56g ±0.2(1.97oz);
Gear type:Titanium Gear;
Speed:0.12sec/60º at (6V)
      0.13sec/60º at (4.8V)
Torque:15.8kg.cm.at(6V)
     14.5kg.cm.at(4.8V)
the features:Waterproof; Plastic case, resist heat and corrosion; Aluminium middle hull, easy to eliminate heat;Adopt high quality coreless motor.
3,XQ-S4020D 20KG高质数码舵机详细规格
XQ-S4020D图片:
型号:XQ-S4020D
品牌:XQ-POWER
Name:6V20kg-cm Digital Servo;
Speed:0.13sec/60º at (6V)
      0.15sec/60º at (4.8V)
Torque:20kg.cm.at(6V)
       17.2kg.cm.at(4.8V)
coreless motor.
二:XQ-POWER XQ-S50系列高质数码舵机详细舵机参数!
XQ-S5040D舵机图片
型号:XQ-S5040D
品牌:XQ-POWER
Name:6V40kg-cm Digital Servo;
Size :A:60.1mm B:30.1mm C:59.7mm D:68.5mm E:16.9mm;
Weight:177.5G(6.25oz);
Gear type:Metal Gear;
Speed:0.20sec/60º at (6V)
      0.18sec/60º at (7.2V)
Torque:33.5kg.cm.at(6V)
       39.8kg.cm.at(7.2V)
舵机品牌:XQ-POWER
公司总机:0755-29370992
官方网址:www.xq-power.com
深圳市艾克斯瑞模型电子有限公司
