本帖最后由 zch 于 13-1-12 09:56 编辑 一早为大伙带来两条强心剂,XB4发布免费升级套件,AE发布B4.2。消息来源ultimaterc.com 首先是XB4发布的免费升级套件 Xray have just announced the soon release of a free upgrade package for all XB4 owners. The set will address reliability issues some racers report and comes with a revised front bulkhead, several gears and reinforcement plates. Here is what Xray has to say: "Despite the long term performance and durability testing to which the XRAY XB4 was subjected by the factory and R&D team, several XB4 customers have reported minor issues in crash situations. XRAY has been well known to fully stand behind their products and is known for providing first class customer service and support. Even though the reported issues have affected only a small portion of XB4 owners, XRAY felt that it would be prudent to provide a free XB4 upgrade package to all XB4 owners through the shop where the kit was originally purchased. The package will include: - Improved 35T diff gears V2 - they have symbol 35 on the back of the gear. Replace both front and rear. The new gear reduces play of the internal satellite gears inside the diff to reduce the risk of damage to the satellite gears - Replacement internal diff gears - no change to the parts, just a free spare for those whose gears may have been damaged due to the 35T gear issues. No need to replace if the original ones are undamaged - Reinforced front diff bulkhead V2 - to replace front bulkhead to increase durability in crashes - Reinforcement for the front shock tower - to reinforce the shock tower in serious crashes - Reinforcement for rear roll center positions - to reinforce the camber link assembly on the rear shock tower in serious crashes These upgrade packages will start shipping next week, however, it will take some time until the packages will reach all distributors and they are able to distribute them to the shops." 大致就是改换了更结实的波箱壳和差速齿,买了XB4的同学们可要抓紧索要啊。具体请楼下翻译 无视外界对B5的强烈诉求,AE最新发布了rc10B4.2,在B4.1世界赛版的基础上添加了12mm大避震器以及相应的避振塔,不用再打磨支架了。改换了前后六角接合器,貌似还换了随车的外胎。任然配备的珠差,不过做了轻量化处理。 How do you improve on a platform that holds more championship titles than any other chassis in its class? You give it the latest Factory Team high-performance option parts. The new RC10B4.2 Factory Team Kit features 12mm Big Bore threaded shocks, VTS slipper clutch, blue aluminum bellcrank set, and 12mm wheel hexes. Ready to make it to the top of the podium? Let the B4.2 Factory Team Kit take you there! B4.2 Factory Team Kit Features: Factory Team 12mm "Big Bore" hard anodized aluminum threaded shocks with TiN "Gold" 3mm shock shafts VTS slipper (variable torque, multi-plate slipper with 3 drive surfaces) assembly featuring a high-resolution spring Factory Team blue aluminum bellcrank set Factory Team 12mm blue aluminum front and rear clamping hexes with hex wheels Factory Team 7075-T6 blue aluminum 0° rear hubs with oversized outer bearing +8mm B4 chassis and Pro-Line Bulldog +8mm body Updated shock towers optimized for the 12mm "Big Bore" shocks Ball differential with light-weight outdrives Factory Team carbon fiber battery strap and blue aluminum thumb screws CVA joints with pin retainer clips Factory Team rear ballast weight Factory Team blue titanium turnbuckles Complete set of precision ball bearings Factory Team blue aluminum hinge pin brace, milled motor plate, servo mounts, and much more! #9041 RC10B4.2 Factory Team Kit Available: February 2013 UPC: 784695 090415 |
