发表于 13-1-4 11:03:48 |显示全部楼层
EDS-290801   SPECIALIZED TOOLS SET FOR 1/10 EP WITH ALU. CASE
    EDS-110115 ALLEN WRENCH 1.5 X 120MM
    EDS-110120 ALLEN WRENCH 2.0 X 120MM
    EDS-110125 ALLEN WRENCH 2.5 X 120MM
    EDS-110130 ALLEN WRENCH 3.0 X 120MM
    EDS-150155 NUT DRIVER 5.5 X 100MM
    EDS-150170 NUT DRIVER 7.0 X 100MM
    EDS-181001 CHASSIS DROOP GAUGE  BLOCKS 10 MM FOR 1/10 (2)
    EDS-181004 CHASSIS DROOP GAUGE -3 TO 10 MM FOR 1/10 CARS (10 MM)
    EDS-181008  RIDE HEIGHT GAUGE 0 MM TO 15 MM (BEVELED)
    EDS-181010 4mm & 3/32" ALU NUT FOR 1/10 SET-UP SYSTEM (4)
    EDS-181012 ALU SET-UP WHEELS 1/10 (4)
    HSP-107750 HUDY GRAPHITE QUICK CAMBER GAUGE 1.5°; 2°; 2.5°
    EDS-199451 EDS ALUMINUM CASE FOR 1/10 EP
    EDS-199206 EDS Pit Towel 110 x 70 cm
http://www.team-eds.com/index.ph ... 10-ep-with-alu-case
