2013 new f1
查看: 2968|回复: 5| [复制链接]
dom 超级元老 发消息
发表于 12-12-13 20:07:12 |显示全部楼层 来自: 中国上海
Specifications
•        2.5mm Main Chassis and 2mm Upper Chassis machined using imported premium grade woven carbon graphite
•        Front 7075 alum bulkhead
•        Front Double Wishbone Suspension
•        Front Independent Dampers
•        Front Droop adjustment
•        Ultra flexible impact resistant rear wing and front wing mount
•        Pivot Ball Rear Pod design with side springs and drag link
•        Standard or Low Profile Servo
•        Rear Axle Height adjustments in 0.5mm increments
•        Ultra low CG 7075 Alum motor mount and bulkhead for Brushed and Brushless motors
•        1/12th specs ¼” rear axle and differential with 1/8” diff balls
•        Processed hardened steel diff plates
•        Symmetric stroke through shaft design Coil Spring Oil Filled Dampers all round, 3 standard and one oversized center damper for superior shock absorption
•        PTFE Coated Hardened Alum Damper bodies
•        Adjustable battery pack stoppers – standard or shorty Lipo packs ready
•        Centralized weight distribution
•        Camber caster adjustable
•        Reactive caster adjustable optimized for carpet racing
•        Complete rolling chassis with tire and body set
•        Titanium Turnbuckles
•        First kit from 3 Racing to bare the “Factory Racing Products” label
疯狂活塞 超级元老 发消息
发表于 12-12-14 09:09:23 |显示全部楼层 来自: 中国上海
淘淘多上点图片啊,这个看着很有爱
eddliang 终极 Fans 发消息
发表于 12-12-14 09:54:56 |显示全部楼层 来自: 中国上海
等到1月都要等。{:soso_e116:}{:soso_e179:}
gxmdyw 长老 Fans 发消息
发表于 13-1-10 21:35:43 |显示全部楼层 来自: 中国吉林长春
多点图片就好了
gzm2345 金牌 Fans 发消息
发表于 13-1-11 23:26:53 |显示全部楼层 来自: 中国上海
这车架要多少米呀~
平跑飞飞 超级 Fans 发消息
发表于 13-1-12 20:33:52 |显示全部楼层 来自: 中国广东广州
这车子能跑多少码啊
