2013年初会出现的NEW F1
查看: 7030|回复: 29| [复制链接]
dom 超级元老 发消息
发表于 12-12-13 19:23:27 |显示全部楼层 来自: 中国浙江湖州
更多图片请去F1区:http://www.rcfans.com/forum.php? ... 24225&extra=&page=1
Specifications
•        2.5mm Main Chassis and 2mm Upper Chassis machined using imported premium grade woven carbon graphite
•        Front 7075 alum bulkhead
•        Front Double Wishbone Suspension
•        Front Independent Dampers
•        Front Droop adjustment
•        Ultra flexible impact resistant rear wing and front wing mount
•        Pivot Ball Rear Pod design with side springs and drag link
•        Standard or Low Profile Servo
•        Rear Axle Height adjustments in 0.5mm increments
•        Ultra low CG 7075 Alum motor mount and bulkhead for Brushed and Brushless motors
•        1/12th specs ¼” rear axle and differential with 1/8” diff balls
•        Processed hardened steel diff plates
•        Symmetric stroke through shaft design Coil Spring Oil Filled Dampers all round, 3 standard and one oversized center damper for superior shock absorption
•        PTFE Coated Hardened Alum Damper bodies
•        Adjustable battery pack stoppers – standard or shorty Lipo packs ready
•        Centralized weight distribution
•        Camber caster adjustable
•        Reactive caster adjustable optimized for carpet racing
•        Complete rolling chassis with tire and body set
•        Titanium Turnbuckles
•        First kit from 3 Racing to bare the “Factory Racing Products” label
E47085 超级元老 发消息
发表于 12-12-13 20:44:49 |显示全部楼层 来自: 中国上海
赞。。。。。
dom 超级元老 发消息
发表于 12-12-13 21:17:11 |显示全部楼层 来自: 中国浙江宁波
E47085 发表于 12-12-13 20:44
赞。。。。。
龟速车手 超级 Fans 发消息
发表于 12-12-13 21:19:01 |显示全部楼层 来自: 中国香港
3 Racing{:soso__9840781690944733863_1:}
dom 超级元老 发消息
发表于 12-12-13 21:23:25 |显示全部楼层 来自: 中国浙江宁波
大概1月上市,有KIT和KIT+SP有感ESC+17.5T的套装两种选择
KIT内应该含竞速壳,头尾翼,103海绵轮
7075金属件+碳材+含碳塑料+4个油压...3RACING这次很用心!
dom 超级元老 发消息
发表于 12-12-13 21:30:21 |显示全部楼层 来自: 中国浙江宁波
攀爬仔 金牌 Fans 发消息
发表于 12-12-13 21:35:47 |显示全部楼层 来自: 中国广东珠海
哇。这车都是全新的设计喔···{:soso_e102:}
winine 论坛元老 发消息
发表于 12-12-13 21:37:51 |显示全部楼层 来自: 中国浙江杭州
千呼万唤始出来啊    看起来不错    期待实物:em07::em07::em07:
小天 超级元老 发消息
发表于 12-12-13 21:38:14 |显示全部楼层 来自: 中国浙江台州
看设计很喜欢、、、如果能有粉色以外的比如黑色特别版就好了。。。。
dom  大牌有台全OP便便色FGX,当然这是靠关系的,呵呵  发表于 12-12-13 21:42
发表于 12-12-13 21:46:23 |显示全部楼层 来自: 中国广东广州
看来第二季不是你和钱大师对手了[便便][便便][便便]
肥仔威  看来你们还是忘不了我的电池啊  发表于 12-12-14 00:42
dom  你不用每次来就可以了,或多带点电池去机场,拜托  发表于 12-12-13 21:52
