Finally after many years developing the original engine ecu a complete new ecu has been designed. Taking all the features of the original unit, the new mk2 version has even more features with virtually unlimited possibilities for the future in other applications. The new ecu is also smaller and lighter than the original As with the original ecu, only 2 wires are connected to the kill switch, and the unit displays:- Customer name. Software version. Previous run time. Last 3 previous peak rpm. Total engine running time. Current run time. Current rpm. This runs peak rpm. Rpm range/display up to 25650 in 50rpm increments. The user can access a system info menu, which displays:- Total ecu running time. The number of times the engine/system has been started. User reset option for the total engine running time. Plus of course built in ignition timing adjustment, with more control than the original ecu which means even greater effect/power!. Fail safe built in. Servo outputs for mixture and coolant control, plus specific timing to suit the demands of boat racing. 就是他的功能啦 你说的挺对的 跟真车ecu 肯定差距大大地 但是对于模型来说比较碉堡了 |
官网介绍翻译如下: 旧版的所有功能不变,MK2新版本具有更多的功能,未来在升级程序后,功能几乎是无限的。新的ECU比原来的体积更小,重量更轻,只有2根导线连接到熄火开关,显示: -客户名称, 软件版本。 累计运行时间。 最近3次的峰值转速。 总发动机运行时间。 当前的运行时间, 转速。 运行峰值转速。 转速范围50RPM到25650RPM。显示分辨率50RPM。 用户可以访问系统信息菜单,其中显示: 总的运行时间。 启动引擎/系统的次数, 发动机的总运行时间。用户重置选项。 加上内置的点火正时调整, 调整的引擎完成一个完整的NOS系统,ECU控制注射,可编程油门和转速的NOS激活点。以及温度输入,定时调整和减速时的NOS是否激活和NOS的电磁阀延迟。 |
