Castle Creations Mamba XL2 34V 750kV Brushless System HPI 1/5 BAJA 專用油改電套件組全套 This is the Castle Creations 2028 780kV Sensorless Brushless Motor and the Mamba XL 2 34V 8S LiPo 5A BEC Electronic Speed Control Combo. FEATURES: Motor, CSEC2800- Designed for 1/5 scale off-road vehicles such as the HPI Baja series Sealed to keep out dirt and moisture Rotor is assembled with four 4-pole neodymium magnets Advanced slotted design stator with super thin steel laminations High-quality sealed ball bearings 8mm hardened steel shaft ESC, CSEM8101 Compatible with brushed or brushless motors Forward/Brake only, Forward/Brake/Reverse, Reverse Lockout Punch/Traction control Drag Brake Adjustable cutoff voltage Compatible with 8S LiPo cells 5 amp BEC (battery eliminator circuitry) Castle Link compatible for more programming features accessible through a Windows PC (Castle Link USB adapter required, CSEM9999) One year limited warranty on both components through Castle Creations beginning at date of purchase INCLUDES: Castle Creations 2028 780kV Brushless Motor with 8AWG Motor Leads and 5mm Female Bullet Connectors, Mamba XL2 Version 2 34V ESC SPECS: Motor- Length: 4.4" (113.2mm) Diameter: 2.2" (57mm) with fins Shaft Diameter: 0.31" (8mm) Shaft Length: 1.18" (30mm) Weight: 44oz (1247g) Max RPM: 30,000 kV: 780 Motor Mount Spacing: 1.18" (30mm) ESC- Max Cells: BEC: 5A Size: 4.1 x 2 x 1.7" (104.1 x 52 x 43.8mm) Weight: 8.5oz (241g) with wires 5.6oz (158.7g) without wires Motor and Battery Wire Size: 8 gauge 線上翻譯 這是城堡創作2028780kV無傳感器無刷電機 和曼巴XL34V8S鋰電5A BEC電子速度控制組合。 特點:電機,CSEC2800 專為1/5規模的越野車,如HPI下系列 密封,以防止灰塵和濕氣 轉子組裝4個4極的釹磁鐵 先進的溝槽設計定子具有超強的薄鋼片 高品質的密封球軸承 8毫米淬硬鋼軸 ESC,CSEM8101 與有刷或無刷電機 前進/剎車,前進/剎車/反轉,反轉鎖定 打孔機/牽引控制 拖剎 截止電壓可調 8S鋰聚合物電池兼容 5安培BEC(電池消除器電路) 城堡Link兼容更多的編程訪問的功能 通過Windows PC(USB適配器所需的城堡鏈接,CSEM9999) 通過這兩個組件城堡的一年有限保修 創作在購買之日起開始 包括:城堡創作2028780kV的無刷電機8AWG汽車信息 5mm的女子彈頭連接器,曼巴XL2第2版34V ESC 詳細參數:電機 長度:4.4“(113.2毫米) 直徑:2.2“(57毫米),鰭 軸直徑:0.31“(8毫米) 軸長度:1.18“(30毫米) 重量:44盎司(1247克) 最高轉速:30000 KV:780 電機安裝間距:1.18“(30毫米) ESC- 最大單元: BEC:5A 尺寸:4.1×2×1.7“(104.1×52×43.8毫米) 重量:8.5盎司(241克)線 沒有電線5.6盎司(158.7克) 電機和電池線尺寸:8計 http://www.castlecreations.com/products/baja_conversion_kit.html Conversion kit, Mamba XL ESC, Neu-Castle 2028 780kv Motor, and CC Blower Fan Shroud |
