FOUR VELOCITI BRUSHLESS MOTORS…FROM FAST TO FASTER! Irvine, CA – February 9, 2006 — The next installment in Novak’s Velociti-series brushless motors is the Velociti 7.5R (#3407). The 7.5-turn, sensor-based brushless motor is ideal for off-road applications that require less than maximum power for low traction settings, yet requires an ultra-smooth throttle response. The addition of the Novak 7.5-turn motor, along with the January release of the 4.5-turn motor, brings the number of Velociti motors to four! The number of GTB/Velociti systems is also growing with Novak’s introduction of the GTB/Velociti 4.5 Racing Brushless System (#3001) and the GTB/Velociti 7.5 Racing Brushless System (#3007). Novak’s Velociti 4.5R Racing Brushless Motor (#3404) is Novak’s fastest motor to date, and the GTB/Velociti 4.5 Racing Brushless System has unbeatable brushless performance for competition touring cars. GTB/VELOCITI BRUSHLESS SYSTEMS Novak’s GTB/Velociti systems include all of the extra performance-enhancing components required for world-class racing, making them ready-to-race straight out of the box (nothing extra to buy or install). Because the Velociti motor was specifically developed for the GTB, and the entire system is factory-tested, racers can be assured that the GTB/Velociti system will provide optimum performance. VELOCITI BRUSHLESS MOTORS All Velociti brushless motors feature a higher-strength magnet for top racing performance, and an oversized front bearing for increased load handling and bearing life. The Velociti motors are specifically designed for R/C vehicles, are sensor-based for excellent braking and low-speed driveability, have low cogging, provide longer run-times than brushed motors, and meet all ROAR specifications. Additional features include direct-solder wiring tabs, locked rotor protection, thermal overload protection, and a virtually maintenance-free design. To see which motor is best suited for you, see below: #3404/#3001 Velociti 4.5R Ideal for competition touring cars and faster than the Velociti 5.5R #3405/#3002 Velociti 5.5R Ideal for competition touring cars and high-traction off-road applications #3406/#3003 Velociti 6.5R Ideal for off-road and low-traction applications and faster than the Velociti 7.5R #3407/#3007 Velociti 7.5R Ideal for off-road and low-traction applications GTB RACING BRUSHLESS/BRUSH ESC All Velociti-series brushless motors are compatible with the Novak GTB Programmable Racing Brushless/Brush ESC so there is no speed control to update. This versatile ESC can be used with either brushless or brushed motors, has no brushed motor limit, and is compatible with all Novak 540-size sensored brushless motors, including the Velociti-series, as well as Novak’s SS-series (SS5800 [8 1/2-turn], and SS4300 [10 1/2-turn]). The programmable GTB ESC has a user-friendly interface that includes 4 different color status LEDs that make programming extremely easy. The brushless mode has 4 adjustable parameters, including Minimum Brake, Drag Brake, Deadband, and Minimum Drive. The brushed mode is fully programmable with all of the adjustments of the brushless mode, plus adjustable Drive Frequency. Other key features include the newest state-of-the-art MOSFET technology, a factory-installed heat-sink and cooling fan, One-Touch Set-Up, direct-solder wiring tabs, and a replaceable input and switch harness. It’s also equipped with Thermal Overload Protection and a water-resistant case. The GTB can be purchased individually, or as part of one of the new brushless systems. The GTB/Velociti 4.5R system is scheduled to ship mid-February 2006. The Velociti 7.5R motor and GTB/Velociti 7.5R system are scheduled to ship end of February 2006. Part numbers and list prices for the new Velociti brushless motors and the new GTB/Velociti brushless systems follow: RETAIL PRICE INFORMATION #3404 Velociti 4.5R Brushless Motor $129 (now shipping) #3407 Velociti 7.5R Brushless Motor $129 #3001 GTB/Velociti 4.5 System $435 #3007 GTB/Velociti 7.5 System $425 INCLUDED ITEMS #3001 GTB Racing Brushless System 4.5: Includes GTB Racing Brushless/Brush ESC factory wired to a Velociti 4.5R Racing Brushless Motor, cooling fan mounted on a factory-installed heat sink, factory-installed power capacitor, instructions, spiral wrap, tie wraps, mounting tape, decal, and 120-day warranty. #3007 GTB Racing Brushless System 7.5: Includes GTB Racing Brushless/Brush ESC factory wired to a Velociti 7.5R Racing Brushless Motor, cooling fan mounted on a factory-installed heat sink, factory-installed power capacitor, instructions, spiral wrap, tie wraps, mounting tape, decal, and 120-day warranty. #3407 Velociti 5.5R Racing Brushless Motor: Velociti 7.5R Racing Brushless Motor, instructions and 120-day warranty. VELOCITI BRUSHLESS MOTOR FEATURES High-strength magnet for top racing performance Oversized front bearing for increased load handling and bearing life Sensor-based for excellent braking and low-speed driveability Lowest possible copper loss (3.1 m phase to phase resistance) Lightweight, ribbed end bells (Velociti 4.5R) Provides approximately 20% longer run-times compared to brushed Specifically designed for R/C vehicles Direct-Solder Wiring Tabs Virtually maintenance-free Thermal Overload Protection Low cogging Meets all ROAR specifications Developed and manufactured in the USA by Novak VELOCITI BRUSHLESS MOTOR SPECS TURNS: 4.5 (#3001 System & #3404 Motor); 5.5 (#3002 System & #3405 Motor); 6.5 (#3003 System & #3406 Motor); 7.5 (#3007 System & #3407 Motor) DESIGN: Sensor-based MOTOR SIZE: 2.08” L X 1.41” D (52.8 x 35.8 mm) SHAFT DIAMETER: 0.125” (3.2 mm) [accepts all existing pinion gears] MOTOR WEIGHT: 6.73 oz. (191 grams); 4.5R: 6.61 oz. (187 grams) MAGNET: One-piece, multi-pole cylindrical high-strength Neodymium GTB ESC FEATURES Uses more than twice the number of MOSFETs as the GTX for ultimate brushed motor performance Ready-to-race straight out of the box (nothing extra to buy) Multiple brushless programmable throttle profiles 4 Adjustable Parameters in all profiles: Minimum Brake, Drag Brake, Deadband, and Minimum Drive Fully programmable racing brushed mode including adjustable Drive Frequency User-friendly programming interface with 4 different color status LEDs Novak’s One-Touch Set-Up (still the easiest) Gold-Plated PCB Direct-Solder Wiring Tabs User-replaceable input harness and switch harness Locked Rotor and Thermal Overload Protection Radio-Priority Circuitry Polar Drive Circuitry Clear cooling fan (30x30x8mm) mounted on factory-installed heat sink Water-resistant case Developed and manufactured in the USA by Novak GTB ESC SPECIFICATIONS CELLS: 4-6 (FWD/BRK/REV) THROTTLE PROFILES: Multiple brushless, 1 brushed MOTOR LIMIT: Compatible with all Novak Velociti and SS-Series, No brushed motor limit ON-RESISTANCE: 0.00040 ohms (brushless x 2); 0.00013 ohms (brushed mode) BEC: Heavy-duty 6V/3A FOOTPRINT: 1.16” x 1.49” (29.5 x 37.8 mm) WEIGHT: 1.36 oz. (38.5 g) |
