jetso 论坛元老 发消息
发表于 06-2-9 01:38:49 |显示全部楼层 来自: 中国广东广州
因为Hara要开始投入更多时间在越野车上面, 推动HPI/HB的油动越野发展, 所以........HB要出新车了..:不过这两台车是RTR的...
首先是:
Lightning 10
然后是:
[ 本帖最后由 jetso 于 2006-2-9 01:49 编辑 ]
jetso 论坛元老 发消息
发表于 06-2-9 01:39:01 |显示全部楼层 来自: 中国广东广州
第一辆车:Packed with proven features from its 1/8 scale cousin the Lightning 10 ready to run buggy is amped up and ready to roar! Complete with a Power Factory 2.6 racing engine, jump-start starting system, TF-3 radio system, pre-printed body and more! Buy it, start it and race it!
   Features:
• Pre-assembled Chassis
• 3 Diff. 4WD Shaft Drive System
• 3mm Aluminum Main Chassis (6061-T6)
• Front & Rear 3mm Aluminum Shock Tower (6061-T6)
• Low Profile Aluminum Radio Tray
• Dual Disc Brake System
• .15 Engine With Jump Start
• Composite Long Suspension Arms
• Front & Rear Oil-filled Long Shocks
• 75cc Fuel Tank
• Aluminum Tuned Pipe
• 46T Spur Gear With Slipper Clutch
• Full Ball Bearing
• 4 Bevel Differential (3 Sets)
• 2pcs Racing Clutch
• Low Profile Body (pre-printed and trimmed)
• Racing Wheels & Tires
• Front & Rear Sway Bars
• Radio & Radio Gear  Items Needed:
• 20% Nitro Car Glow Fuel
• Fuel Bottle
• Glow Plug Igniter
• Glow Plug Wrench
• Battery (aa) X 12
• Battery (7.2volt)
• Battery Charger
第二辆车:Bringing the fun of 1/8 scale to the masses!
1/8 scale has to be one of the most exciting forms of R/C racing around. It is also one of the most expensive forms of R/C racing around. The solution? Our new Lightning 2 Sport! The Lightning 2 Sport comes with everything you need to get started as well as some extras! Not to mention it's the same basic design as the Lightning 2 Pro that won the National Championships!
1/8 LIGHTNING 2 SPORT Features:
• 6061(T6) 4mm Front and Rear Shock Towers
• 5052 3mm Main Chassis
• Front & Rear Chassis Braces
• Full Ball Bearings
• Front CVA Axles
• Exhaust-Tip Bash Guard
• Low Profile Fuel Tank
• Low Profile Upper Deck and Receiver/Battery Box
• 22° Hub Carriers
• Hot New Printed and Trimmed Body Design (blue)
• Rear Sway Bar
• 2pc. Racing Clutch
• .26 Engine
• Complete Radio System
• Extra Steering Knuckles and Wing Items Needed:
• Fuel Bottle
• Glow Plug Igniter
• Battery (AA) x 12
HPI TF-3 digital proportional AM super narrowband radio system
[ 本帖最后由 jetso 于 2006-2-9 01:50 编辑 ]
jetso 论坛元老 发消息
发表于 06-2-9 01:42:39 |显示全部楼层 来自: 中国广东广州
jetso 论坛元老 发消息
发表于 06-2-9 01:43:48 |显示全部楼层 来自: 中国广东广州
:em14:
jetso 论坛元老 发消息
发表于 06-2-9 01:44:41 |显示全部楼层 来自: 中国广东广州
jetso 论坛元老 发消息
发表于 06-2-9 01:45:16 |显示全部楼层 来自: 中国广东广州
jetso 论坛元老 发消息
发表于 06-2-9 01:45:57 |显示全部楼层 来自: 中国广东广州
jetso 论坛元老 发消息
发表于 06-2-9 01:46:19 |显示全部楼层 来自: 中国广东广州
jetso 论坛元老 发消息
发表于 06-2-9 01:47:07 |显示全部楼层 来自: 中国广东广州
很有可能会掀起一场越野价格风暴, 估计走MTA4 II的路线! 超高性价比!
jetso 论坛元老 发消息
发表于 06-2-9 01:51:18 |显示全部楼层 来自: 中国广东广州
Lightning 2 Sport
22 degree hub
