This 1/10 scale 4WD buggy is specially designed to excel in off-road buggy racing. It features a mid-rear mounted motor and longitundinally mounted battery for optimum balance for jumping. Battery is inserted through the bottom of the chassis, eliminating need to remove body, which makes routine maintenance easy and quick. High performance shaft drive 4WD combines with suspension system featuring extra long suspension arms for improved stability and off-road handling. |
