TRI90010, "Blade" ( Ready to Run ): - Side By Side Battery Mounting - Ball Diffs (super smooth and long wearing) - Oil Filled Shocks - Aluminum Motor Mount - Beefed Up Suspension Arms - Heavy Duty Ball Ends and Revised Mounting Position - New Style 2 Piece Electronics, Separate Speedo and Receiver - Ready To Run & Pro Chassis Versions Only ---------------------------------------------------------------------------------------- TRI90009, "Blade" (Pro Rolling Chassis): - Fully assembled chassis. - Longer wheelbase for improved handling and greater off-road stability. - Oil filled shocks. - Heavy duty ball ends. - Heavy duty fully adjustable tie road upper suspension arm. Easy to adjuster camber. - Front and Rear heavy duty ball differentials for improved cornering and straight line traction. - Clear trimmed super slammed unmounted racing body. - White dished wheels. - Heat sink motor mount. - Beefed up suspension arms. - Mini servo installed. - Uses 6 cell side x side battery packs. - COMES WITH FREE MOTOR: $29.99 value |
