wangxin1944 RC 新手 发消息
发表于 12-6-15 13:25:34 |显示全部楼层 来自: 中国北京
Hi,
For all of you who are trying to make some decisions about buying Kyosho DRX I will try to write some pros and cons of this car.
pros:
- It's a real rally car, not like all of those on-roads like FW-05, V-Rs, etc.. with Subaru Impreza body and a slick tires etc.
- DRX was made from a buggy kind of car so it's ready to go off-road, it's also good for tarmac, but in my opinion best place for it is a gravel and some dirt (dry dirt if you don't wont to do a 5 hours cleaning after run).
- It have a nice engine GXR-18 (it's not a true small block, and not a big block as well, just like this car - it's not a 1/8 and not 1/10 ... its a 1/9 ).
The engine is enough to create some rally experience, it's easey to tune and easy to start (with pull-starter).
- It's a solid construction, I saw some kind of a crash test of it, when one of DRXes was accidentally hit by a 1/5 scale Petrol monster-truck at high speed on a local track.
- All shafts are made of some kind of metal (but be careful when buying a RTR kit, I saw few with bended drive shafts), so it's very hard to brake it.
- Receiver and batteries are hidden in a plastic case so it's safe to go dirty .
- Differentials (there are 3) are making great job in this car, even in RTR out-of-the box car.
- There are two disk brakes and you can set how much force of braking you will get on front and rear wheels independently (just like a real car do).
- It's a great looking car (maybe except Lancia Stratos body, but it's my opinion)...
- Fantastic engine sound
cons
- I have not found anything major, but be careful with READY KITs, before buying one take a look on shafts (all should be straight). Don't run it before checking if tires are properly glued to the rims, If not ask seller to glue it precisely, or do it yourself. With tires not glued fine to the rims you will risk braking the tire. /tires are expensive/
- throtle revers spring is way to soft and it doesn't work at all. /not big deal 3$ and you can get a proper one or spend more money and buy a fail-safe/
- The golden carburetor (see pic.) screw is poorly secured, so pay special attention to it and examine it after/before every racing session. If it will unscrew (and believe me it will) use some silicon sealant /special one/ (add very little - think little and then divide the imagined amount by 9 /scale 1:9/) before you will tighten it again.
If some day your are unable to start your engine or your engine do strange things I might be this screw.
- Batteries are well hidden, but putting cover on battery box is a nightmare. also you have to be very careful when putting batteries inside the box. You can easily brake cables.
发表于 12-6-15 15:17:53 |显示全部楼层 来自: 中国天津
您写的好辛苦,不过这是在中国
发表于 12-6-15 15:54:16 |显示全部楼层 来自: 中国北京
在别的论坛摘的,后续跟上翻译
天堂向左 金牌 Fans 发消息
发表于 12-6-15 23:58:48 |显示全部楼层 来自: 中国江苏苏州
坐等翻译或者坐等lz被喷
发表于 12-6-16 08:08:33 |显示全部楼层 来自: 中国天津
翻译跟上 分两段说:第一段是优点,第二段是缺点
发表于 12-6-16 08:20:00 |显示全部楼层 来自: 中国天津
嗨,
写给所有那些想买京商DRX的一些人,我会尽量写一些这款车的优点和缺点。
优点:
- 这是一款真正的拉力赛车,而不是其他的on-road车,如FW-05 V-RS等。 它拥有斯巴鲁翼豹的车壳和越野轮胎
- DRX是基于越野车的底盘,所以它时刻准备着去跑越野,同时也很适合跑柏油路段,但在我看来,最适合它的地方是砾石和土路(请选择干的土路,如果你不介意跑完花5小时清洗)
- 它有一个很好的引擎GXR-18(它不小不大,就像这辆车 - 它不是一个1/8或1/10,而是1/9 )。
- 此款发动机足以给你带来真正的拉力体验,并且容易启动(拉起动)
- 这是一台结实的车,我看到过一些碰撞测试,DRX意外被一辆1/5汽油高速怪物卡车在赛道上撞到而毫发无损。
- 所有轴都是金属的(但买RTR时要小心,我曾经看到过一些弯曲的传动轴,请购买时一定要仔细检查)
- 接收器和电池都隐藏在一个塑料外壳,所以你可以放心让它在脏的地方跑。
- 它有两个盘式制动器,并可以自由设置制动力,你可以独立分配前后制动力量(就像一个真正的汽车一样)
- 这是一台伟大的车(也许除了车壳,但我保留意见)...
- 神奇的引擎声!
Axman 终极 Fans 发消息
发表于 12-6-18 08:15:01 |显示全部楼层 来自: 中国江苏
缺点呢?
还有和WR8 3.0比哪个好?
发表于 12-6-18 12:28:40 |显示全部楼层 来自: 中国北京
缺点:
-我并没有发现任何重大的缺点,但要提醒各位开包时,一定要提前一看轴(检查是否直)。另外跑它之前要检查轮胎与轮辋是否粘好,如果网购,可以要求要求卖方检查或者提供胶水,如果轮胎与轮辋之间没有粘牢的话,制动时会损坏轮胎。轮胎可是很贵的。
-油门反弹弹簧感觉有点软,不能很好工作。换一个好的也没什么大不了,还是买一个换上安全
-金色的那个化油器螺丝不太稳固,所以要特别注意它,在每次跑或者比赛之前要检查一下。如果它松开了(相信我,它会的),可以加入少量硅密封胶,然后将它拧紧。
如果有一天你无法启动你的引擎,或者引擎运行不正常,那么很可能是这个螺丝的问题。
-电池隐藏得很好,但在电池盒上装一个盖子则不是什么好主意。当把电池塞进去时,你必须非常小心,因为很容易碰断电池线缆。
发表于 12-6-18 12:33:45 |显示全部楼层 来自: 中国北京
回复 Axman 的帖子
我也正在比较WR8 3.0 和 DRX之间的区别(貌似WR8比DRX要贵很多),准备搞清楚之后出手,有没有高手过来解答一下
dxl1989 超级 Fans 发消息
发表于 12-7-19 23:01:38 |显示全部楼层 来自: 中国江苏无锡
wangxin1944 发表于 12-6-18 12:33
回复 Axman 的帖子
我也正在比较WR8 3.0 和 DRX之间的区别(貌似WR8比DRX要贵很多),准备搞清楚之后出手, ...
我也在纠结这两款 麻烦有结果了PM个信息啊
