介绍一下此车的差速,是很值得像大家介绍的,英语水平不好,谷歌翻译给大家吧,英语好的我附上原版。 The LSDiff is an pure racing component. Reason of his special working mechenism, reduce the spin of the rear inside tire and tats way reduce the laptimes and the temperature of the tires. The developing of the LSDiff started at the begining of 2003. At the begining the diff was only working at hight grip track, like European Championship. Affter 5 Years of developing and optimalising at the end of 2008 the LSDiff was avelible for everybody. Now the LSDiff works at low and height grip condition well, and help the drivers to beet Track Records and wining races. The LSDiffs since now winning 4 European Championship titles. LSDiff是一个纯粹的赛车组件。他特殊的工作mechenism的原因,减少轮胎内的后方旋转,并TATS方式减少的赛况和轮胎温度。发展中国家的LSDiff开始于2003 begining。在begining的差异,只有工作在hight握轨道像欧洲足球锦标赛“。 affter5年的发展,并在2008年年底optimalising大家的LSDiff avelible。现在低和高度抓地力条件LSDiff的作品,并帮助司机甜菜记录和打赢比赛。 因为现在赢得4个欧洲锦标赛冠军的LSDiffs。 You can use Your LSDiff at different Track conditions. For wet or low grip tarck You can mount to bouth side the "deactivation ring" (First picture). With the 2 pcs "deactivation ring" You have much more tarction then with an "normal differential. By mounting one side an baking mechanism (second Picture) , You will have optimal traction for medium grip tarcks. By changing the size of the brake disk You can increase the locking effect, so You will find the right setup for every condition. By mounting the bracking mehanism on bouth side (third picture) , You will have maximum traction. This version are ideal for extrem height grip track, like European Championship. 你可以使用不同的赛道条件你的LSDiff。对于潮湿或低抓地力tarck,你可以安装到bouth方的“失活环”(第一张照片)。与2个“失活环”你有更多tarction然后有一个“正常的差。安装一方烘烤机制(第二图),您将有中等抓地力tarcks最佳牵引通过改变制动盘的大小。你可以增加锁定效应,所以你会发现通过安装bouth侧(图片三)bracking mehanism每条件的设置。,您将有最大的牵引力。这个版本是理想为EXTREM高度抓地力的赛道,像欧洲锦标赛,。 You can choice from 6 differnt bracking disks, to find the perfect traction for every condition. 3 of them are made from special epoxy material and 3 of them from special carbonfibre. By increasing the size of the disk You will have more and more traction. 你可以选择从不同的充6 bracking磁盘,找到每一个条件完善的牵引。其中3是由特殊的环氧树脂材料和特殊的碳纤维,其中3。 增加磁盘的大小,你将有越来越多的牵引。 |
