本帖最后由 斯诺克 于 11-12-1 23:23 编辑 请问这个电调和电机适不适合给SAVAGE XS FLUX用?Castle Creations Mamba Monster 2200KV (MMM V3) ![]() 这事参数:(具体的看不懂) INCLUDES: 2200kv Neu/Castle motor 18 tooth Pinion gear Mamba monster version 3 speed control Castle Link hardware REQUIRES: Installing into vehicle SPECS: Motor: Length: 75.5mm (2.97") Diameter: 40.5mm (1.59") Weight: 121g (4.27oz) Shaft Diameter: 5mm (.2") Max Input Volts: 25.2v Amp Rating: 120 Wire Lead Guage: 10 ga ESC: Cells: 18 NiCd/NiMH, 6 cell LiPo Continuous: N/A Resistance: .0003 Ohm Brake: Proportional with adjustable curve Reversible: Yes, with lockout Low Voltage Cut-off: Programmable Size: 2.2 x 1.9 x 1.4" (56 x 48 x 35mm) Weight: 4.3oz (121g) Connector Type: 6.5mm 请老同志们给参谋一下。谢谢了! |
