lg_zb11 终极 Fans 发消息
发表于 11-11-7 20:19:31 |显示全部楼层 来自: 中国河北石家庄
如果大家看着小的话,点一下图片字就大~\(≧▽≦)/~啦啦啦 long-rod-engine-29cc.jpg longrod1_1_2.jpg longrod2_1_2.jpg 29cclongrodtq.jpg 29cclongrodhp.jpg 29cclongrodtq(2).jpg 最近挺痴迷小松引擎,发现其实小松引擎也优良啊 发个几个OBR小松引擎的数据!前辈请指教!
ull Mod - Our top of the line engines. OBR is proud to offer the first production long rod engine! At OBR we take pride in innovating and not duplicating!
View images above for more info on long rod cranks and dyno sheets.
Just when we thought there wasn't any way to top our insane full mods Syndicate came along and gave us the power to do so. The long rod crankshaft along with some new porting allowed us to achieve 7hp.  With the higher reliability of the 4 bolt Zenoah engines we were able to achieve more power with out sacrificing reliability. We put all of the knowledge that we have picked up from years of dyno and field testing and came up with a monster. To start we completely tear down the engines and perform the following modifications:
1. Machine combustion chamber
2. Reshape piston
3. Lighten piston
4. Relieve piston to prevent seizes
5. Modify intake port for better flow
6. Adjust intake duration to our specs
7. Resurface all ports
8. Modify transfer ports for better flow
9. Enlarge and reshape exhaust port
10. Adjust exhaust duration to our specs
11. Remove stock crank and install Syndicate 2mm stroker crankshaft with +3mm connecting rod
12. Install all new gaskets and c-clips when engine is assembled
13. Re-bevel all porting and stock bevels to prevent damage to the piston and/or cylinder
This engine fits:
* Tech Note: Installation in an HPI Baja requires that the stock Zenoah clutch be modified for a direct bolt up. Or the clutch from your stock fuelie 23/26 can be installed on this engine for a direct bolt up. The last option is a TR/OBR sealed clutch housing. The sealed clutch housing can be used with a machined CY clutch plate for a direct bolt up.
Off-road Rc Cars: HPI Baja 5B/5T/5SC, MCD, Rampage, FG Marder, FG Marder Race, FG Monster Beetle, FG Monster Beetle Pro,FG MT5,FG Stadium Truck, Duratrax Firehammer, Carson Attack, Smartech Traveller,FG Leopard, XTM, Leopard Race, FG Leopard STX, FG Marder Beetle, FG Pajero and most other large scale cars.
On-road Rc Cars: MCD, FG Evo,FG Sportline, HARM,FG F-1 Competition and most other large scale onroad car
翻译:
ULL MOD - 我们的行发动机的顶部。 OBR是自豪地提供了第一个批量生产的长轴引擎! OBR,我们在创新的骄傲和不重复!
以上为长棒曲柄和测功表的详细信息查看图像。
正当我们认为,有没有任何方式顶部我们的疯狂集团的全MODS走过来给了我们这样做的权力。随着一些新移植的长棒曲轴,使我们能够实现7HP。随着更高的可靠性的4个螺栓Zenoah引擎,我们能够实现更大的马力而不牺牲可靠性。我们把所有的知识,我们从多年的测功机和现场测试,我们创造了一个怪物。要开始我们完全拆掉发动机和执行以下的修改:
1。机器燃烧室
2。重塑活塞
3。减轻活塞
4。释放活塞,以防止非法劫持
5。修改为更好地流进气口
6。调整摄入量的持续时间,以我们的规格
7。重铺所有端口
8。修改为更好的流动转移端口
9。放大和重塑排气口
10。调整排气时间,以我们的规格
11。删除股票3毫米连杆集团采用2mm司炉曲轴曲柄和安装
12。安装所有新发动机组装时的垫片和C -片段
13。所有的移植和重新锥股票斜面,以防止损坏活塞和/或气缸
这台发动机配合:
*技术说明:安装需要在HPI下,股票Zenoah离合器直接螺栓更改。或者从你的股票fuelie 23/26离合器可以安装这种发动机直接栓起来。最后一个选项是一个TR / OBR密封离合器壳体。可用于密封离合器壳体加工中青直接栓起来的离合器片。
越野遥控车:HPI巴哈5B/5T/5SC,MCD,横冲直撞,黄鼠狼FG,FG黄鼠狼赛,FG怪物甲壳虫,FG怪物甲壳虫临,FG MT5,FG体育场卡车,Duratrax Firehammer,卡森攻击,敏科旅行者, FG豹,XTM,赛豹,FG豹STX,FG黄鼠狼甲壳虫,FG帕杰罗和其他大多数大型车。
越野遥控车:MCD,FG,FG Sportline,伤害,FG的F - 1
简单的说来,这个引擎就是加长了活塞连杆,达到了加大马力的作用,其他的都是配套和优化措施~\(≧▽≦)/~啦啦啦
屰渁寒 论坛元老 发消息
发表于 11-11-7 20:22:38 |显示全部楼层 来自: 中国新疆乌鲁木齐
沙发!!
小松的很优良的啊!!!!
wyw19780326 超级元老 发消息
发表于 11-11-7 20:50:40 |显示全部楼层 来自: 中国陕西宝鸡
学没上好,看不懂
cat6485 金牌 Fans 发消息
发表于 11-11-7 20:51:18 |显示全部楼层 来自: 中国河北秦皇岛
我感觉改装的引擎都是压榨引擎的动力,虽然性能提高了,但稳定性,可靠性和寿命肯定跟ts,bzm是有区别的。就跟f1引擎一样,性能很棒但寿命很短
lg_zb11 终极 Fans 发消息
发表于 11-11-7 20:59:00 |显示全部楼层 来自: 中国河北石家庄
回复 cat6485 的帖子
\(^o^)/~ 还好~\(≧▽≦)/~啦啦啦 我现在用着还不错
guohuo 论坛元老 发消息
发表于 11-11-7 21:11:49 |显示全部楼层 来自: 中国天津
瞬间的辉煌是短暂的。哈哈
latin 终极 Fans 发消息
发表于 11-11-7 21:37:57 |显示全部楼层 来自: 中国陕西西安
是我没看详细还是少了点什么。
lg_zb11 终极 Fans 发消息
发表于 11-11-7 21:42:33 |显示全部楼层 来自: 中国河北石家庄
回复 latin 的帖子
?没明白 哈哈
geniusyys 超级元老 发消息
发表于 11-11-7 22:08:12 |显示全部楼层 来自: 中国陕西
扭矩很可观啊,就是价格也不低
lg_zb11 终极 Fans 发消息
发表于 11-11-7 22:18:33 |显示全部楼层 来自: 中国河北石家庄
回复 geniusyys 的帖子
599$   3800多人民币吧
