回复 cdx7758 的帖子
是從RC8原形改良進化成RC8B
然後再經過實戰
輕量修正設計
加入新元素
再進化成RC8.2
(重點改良包括~新設計前後油壓架,前後搖臂,防滾桿位置,加長底板)
其他配置大部份是針對強化及偷輕
- Factory Team 3mm lengthened 7075 hard-anodized chassis
- Newly designed suspension arms feature centerline shock mounts and optimized anti-roll bar position
- Factory Team 16mm "Big Bore" hard-anodized threaded shocks with 4mm titanium nitride coated shafts
- Factory Team 5mm 7075 aluminum low-CG shock towers with optimized geometry
- Factory Team 7075 blue aluminum lower suspension mounts for optimized geometry, light weight
- Factory Team 7075 blue aluminum steering knuckles
- Factory Team 7075 aluminum axles and center drives
- Factory Team 7075 blue aluminum one-piece top plate
- Factory Team lightweight spur and ring gears
- Factory Team lightweight diff outdrives
- Factory Team aluminum steering posts
- CVA boots on center and rear drive joints
- Heatsink brake rotors front and rear
- New low-CG wing mount
- JConcepts Punisher Body and Illuzion wing included
- Molded composite radio tray includes optional forward-placement
- Molded composite front and rear chassis braces
- Tough steel-alloy shock standoffs
- Factory Team 83mm "big" wheels included
- Aluminum clutch shoes
- 4.30:1 ratio gearboxes for maximum punch
- Caster blocks adjust 14, 16, or 18 degrees with molded inserts
- 3.5mm light CVA drivetrain with full ball bearings
- Factory Team shock and differential fluids included
- Mud guards
