新款7HP小松30.5CC obr手改
查看: 4358|回复: 15|   [复制链接]
geniusyys 超级元老 发消息
发表于 11-9-19 15:15:50 |显示全部楼层 来自: 中国陕西
7HP FULL MOD ZENOAH 4 BOLT 30.5CC +3MM LONG ROD ENGINE
Full Mod - O'neill Brothers top of the line engines. OBR is proud to offer the first production long rod engine! OBR takes pride in innovating and not duplicating!
Just when OBR thought there wasn't any way to top their insane full mods Syndicate came along and gave them the power to do so. The long rod crankshaft along with some new porting allowed OBR to achieve 7hp.  With the higher reliability of the 4 bolt Zenoah engines they were able to achieve more power with out sacrificing reliability. OBR put all of the knowledge that they have picked up from years of dyno and field testing and came up with a monster. To start they completely tear down the engines and perform the following modifications:
To start they completely tore down the motor and did the following modifications:
  • Machine combustion chamber
  • Reshape piston
  • Lighten the piston
  • Relieve the piston to prevent seizing.
  • Modify the intake port for better flow.
  • Adjust intake timing to OBR specs.
  • Resurface all ports.
  • Modify transfer ports for better flow.
  • Enlarge and reshape exhaust port.
  • Adjust exhaust timing to OBR specs.
  • Remove stock crank and install Syndicate 2mm stroker crankshaft with +3mm connecting rod.
  • Install all new gaskets and c-clips when engine is assembled.
  • Re-bevel all porting and stock bevels to prevent damage to the piston and/or cylinder
该贴已经同步到 geniusyys的微博
geniusyys 超级元老 发消息
发表于 11-9-19 15:16:51 |显示全部楼层 来自: 中国陕西
就手改加上加长3MM曲轴,性能直追TS,价格500USD不到。。。。大家讨论讨论
fwzflqwer 超级元老 发消息
发表于 11-9-19 15:18:59 |显示全部楼层 来自: 澳大利亚
看不懂
S343381150 终极 Fans 发消息
发表于 11-9-19 15:33:10 |显示全部楼层 来自: 中国吉林长春
貌似手改的都用不住吧
ly184173974 论坛元老 发消息
发表于 11-9-19 15:52:18 |显示全部楼层 来自: 中国重庆
看不懂  无法发表任何评论
liusiren2007 超级元老 发消息
发表于 11-9-19 16:43:48 |显示全部楼层 来自: 中国吉林长春
…………今天,你看懂了么~~
wyw19780326 超级元老 发消息
发表于 11-9-19 18:30:59 |显示全部楼层 来自: 中国陕西宝鸡
中文都不完全懂,更别说鸟文了
再见优乐美 超级元老 发消息
发表于 11-9-19 18:39:42 |显示全部楼层 来自: 中国贵州贵阳
今天,你看懂了么。。。。。。
bibilaoda 终极 Fans 发消息
发表于 11-9-19 19:19:16 |显示全部楼层 来自: 中国天津
LZ 能把那鸟语改成中文吗····
BAJA爱车族 超级元老 发消息
发表于 11-9-19 22:05:21 |显示全部楼层 来自: 中国河南郑州
读书时候英语课在睡觉的飘过
