fwzflqwer 超级元老 发消息
发表于 11-9-8 21:28:47 |显示全部楼层 来自: 澳大利亚
HPI马上就要宣布4WD的新1/5车型
著名的losi和著名的BAJA防滚架厂商----team chase合作的新款1/5汽油短卡"5ive--T"已经在TGN有预售消息,价格与5SC差不多但略贵。
Large-bore shocks with 7mm shafts & threaded adjusters
大流量7mm可调避震
5MM chassis with CNC machining for strength and less weight
5毫米CNC底板
Two-stage air and fuelfilter systems
双层空滤,油滤
Powerful Losi® 2-stroke 26cc gasoline engine
26CC 2冲程引擎
1/4 -scale heavy-duty throttle servo for superior braking
1/4 比例 油门舵机提供强力的刹车
Adjustable bias dual-disk braking system
可调节双碟刹系统
1/4-scale high torque metal gear steering servo
1/4比例 高扭力金属转向舵机
Extra-large 800cc fuel tank
800毫升邮箱
Spektrum SR3300T Telemetry Receiver with 2.4GHZ DSM Technology
Spektrum SR3300T接收
Three tunable sealed viscous differentials
三个可调节密封差速器
Multi-piece bead lock off-road wheels
多重卡环固定的越野论坛
Impact Absorbing Bumpers
可吸收撞击的防撞设计
Innovative sealed clutch mount with cooling fins
革命性带有散热鳍片的密封离合器固定
Cv driveshafts used throughout
全车使用CV传动系统
6V 3000mAh Receiver Battery and Charger
6V 3000毫安接受电
Type:4WD Short Course Truck
产品名称:四驱短卡
Scale:1/5
比例1/5
Length:38 in (965.2mm)
Width:20.75 in (527mm)
Height:12.25 in (311.1mm)
Ground Clearance:2 in (50.8mm)
离地间隙
Wheelbase:24 in (609.6mm)
轴距
Chassis:5mm thick 7075 T6 aluminum
主板:5mm厚的7075 t6 铝合金
Suspension:4 wheel independent
悬挂:四轮独立悬挂
Drivetrain:4WD with 3 silicone fluid differentials & centrifugal clutch
动力系统:4驱 带有3个差速器,传统离合器
Tire Type:Off-Road all-terrain Performance high wear
轮胎类型:越野全路况高性能,耐磨损轮胎
Motor or Engine:26cc Gas
引擎:26CC
Radio:BND – Spektrum 3300T Telemetry Receiver
遥控:Spektrum 3300T 接收
Batteries:3000MaH 6V NiMh receiver pack
电池:3000毫安镍氢接收
Charger:Global AC charger
充电器:宽幅交流充电器
Wheel Size:4.75 in (120.6mm)
轮胎尺寸:120.6mm
Kit/RTR:RTR
预组装,到手可玩
Shock Type:24MM diameter oil filled with compensation bladders
避震类型:直径24MM的油压避震
Body:4 piece, Short Course Truck
车壳: 4段,短卡造型
Ball Bearings:Throughout including steering
轴承:全车滚珠轴承,包括转向系统
Fuel Tank Capacity:800CC
800CC容量邮箱
Minimum Age Recommendation:14 years
最小推荐年龄:14岁
Experience Level:Advanced
Recommended Environment:Outdoor
Is Assembly Required:No
翻译匆忙,措辞如有不当之处请指正
特别注意上图,这就是losi特别宣传的4段外壳。
官方说法是如有部分损坏,可以单独购买
losb0019whtbd_a13.jpg LOSB0019BLKBDchassis.jpg GAL08.jpg GAL05.jpg fg2090809.jpg 5-ive_t_03.jpg
根据现在能看到的数据来说LOSI的这款车相对5T/SC有着更低的重心,也相对5T/SC更宽一点。作为结果来说可能乐趣相对5T/SC会略有下降,但是翻车的记录也同时大大降低。
防滚架是原装标配,是个亮点。
总体来说这款车拥有很不错的性价比,相信量产以后价格还会有所下降
===9月10日更新===
smugshot9168911-XL.jpg smugshot7264144-XL.jpg smugshot7248422-XL.jpg smugshot6710295-XL.jpg smugshot1454886-XL.jpg smugshot3520657-XL.jpg smugshot5992585-XL.jpg smugshot6065395-XL.jpg smugshot538323-XL.jpg smugshot212641-XL.jpg
视频
=============HPI 4WD分割线==========
目前关于HPI 4驱的消息还不多,只有在HPI官方facebook上透漏了有限的消息
根据HPI官方facebook的信息,笔者分析这款4wd的车很有可能会在本周末在美帝举行的一度的全国BAJA聚会上发布
笔者刚才在重新浏览图片的时候发现此款车壳上印有FLUX的标志,那么此车很可能与汽油动力无缘了
=======10月11日更新=======
LOSI 5IVE-T 10月25日将在中国正式发售,目前LOSI以及LOSI母公司“horizon hobby"也已经正式登陆中国。
售价要比想象中的厚道很多~   与HPI 5SC几乎持平。
那么对于玩家来说这个消息也意味着5ive-t的配件将会有着充足的供应
期待LOSI 为汽油车玩家带来新的体验
Losi 5ive-t对比5B
CTR 论坛元老 发消息
发表于 11-9-8 21:33:33 |显示全部楼层 来自: 中国河南平顶山
速度来点图片`````````````````````````
ken72999 超级元老 发消息
发表于 11-9-8 21:37:22 |显示全部楼层 来自: 中国湖北黄石
LOSI和HPI,我肯定选择LOSI,吼吼
greatman8763 论坛元老 发消息
发表于 11-9-8 21:58:49 |显示全部楼层 来自: 中国广西柳州
不知价格如何,估计应该又是烧不起的玩意!!
lijiang0620  5SC 国内是 8K出头  发表于 11-9-8 23:22
fwzflqwer  与5SC基本一致  发表于 11-9-8 22:07
ANHX23 终极 Fans 发消息
发表于 11-9-8 22:05:31 |显示全部楼层 来自: 中国北京
我靠 太激动了~
cat6485 金牌 Fans 发消息
发表于 11-9-8 22:11:52 |显示全部楼层 来自: 中国河北秦皇岛
tgn 卖1600刀!期待啊,不知国内上市后卖多少钱!
xjypark  10224....直接換來的數值。。。稅後估計 1W3左右  发表于 11-9-9 08:56
fwzflqwer  直接算汇率是1W,根据惯例在国内上市价格应该在1.2w-1.3w左右  发表于 11-9-8 22:21
S343381150 终极 Fans 发消息
发表于 11-9-8 22:19:51 |显示全部楼层 来自: 中国吉林长春
感觉有点单薄啊...但是四驱很是诱惑..
fwzflqwer  那就期待HPI的四驱吧  发表于 11-9-8 22:29
geniusyys 超级元老 发消息
发表于 11-9-8 22:25:57 |显示全部楼层 来自: 中国福建厦门
losi确实非常短卡。。。。。
geniusyys 超级元老 发消息
发表于 11-9-8 22:27:32 |显示全部楼层 来自: 中国福建厦门
无二楼板的设计,非常不符合国情,国内没赛道,撞墙的大有人在,losi完全是赛道化设计,而且引擎的排列也导致了轴向作用非常明显。。。。
fwzflqwer  轴向作用还是有争议的,而且此车标配防滚架,配合类似于5T的前防撞吸能设计,问题不会太大。 5mm7075的强度也不是摆设  发表于 11-9-8 22:38
S343381150  没防滚架..不上车壳表示压力很大........  发表于 11-9-8 22:34
linlinziai 终极 Fans 发消息
发表于 11-9-8 22:34:23 |显示全部楼层 来自: 中国辽宁鞍山
汽油新革命啊 。      换车型了
