你好。我也是听freeman 说的。因为我的动力和你一样。都是tekin rx 8 sc 4x 5.5t 但是电机有点失望,没有图片那么红。不够心情。。。。。。。。。2极的话你可以试试novak4.5 T 4900kv或5.5t 3500kv的电机。上海有位朋友的410也是用这个动力效果很满意。好盈3672电机起步没什么力的。个人感觉是这样到中后段从会感觉的有速度。我死老鼠就是用好盈120sd加3672,18t 52t起步扭力不够。极速65没开tubro.Aka的轮胎很高性能。平时跑街必要浪费。PRO_LINE公路胎其实没必要。个人认为PRO-Line的大胎纹仿真短卡轮胎更符合实际和耐用。平时玩本全地形通吃。平时很少只跑公路的。只是个人想法。有时间多交流。 |
本帖最后由 freeman118 于 11-7-7 13:42 编辑 回复 tonyjojo 的帖子 550 4X4 Short Course Motor SpecificationsPlease note that these are specifications for 550 motors that are only legal in the 4X4 Short Course Category. 8.8.6 10th scale 4×4 Short Course Truck (SCT) 550 Motor 8.8.6.1 Can: Maximum overall length is 73.0mm measured from the mounting face of the motor to the furthest most point on the endbell, not including solder tabs, lead wires,sensor plug or housing, or the manufacture’s logo or name. Motor mounting holes must be on 1.00 inch (25.40mm) centers. Diameter is 36.02mm 8.8.6.2 Stator: Motor stator minimum length is 35mm (- 0.15mm tolerance) with maximum length of 42mm. The thickness of the laminations shall be 0.35mm. A ‘go-no-go’ gauge 14.500 +0.000/-0.005mm diameter shall pass into the stator, clearing the stator plus its windings and the electrical collection ring at the end of the stator. 8.8.6.3 Rotor: External shaft diameter may be either 0.125 inches (3.175mm) or 0.197 inches (5mm). Only one piece, two pole Neodymium sintered, or Ferrite (Ceramic) magnetic rotors are permitted. The magnet length shall be a minimum of 39.0mm and maximum of 46.0mm not including any nonmagnetic balancing material. The magnet outside diameter shall have a minimum of 12.3mm and a maximum of 14.0mm, no tolerance, for the entire length of the magnet. ***Please refer to the class rules, which indicated that these systems in 4X4 Short Course trucks are limited to 7.4v lipo batteries ONLY. The batteries need to comply with ROAR rules regarding the use of “hard case” packs already approved for use in ROAR competition. Use of any non-approved batteries or higher voltage 3S or 4S packs is strictly prohibited. There will be no exceptions. This entry was posted on Thursday, June 23rd, 2011 at 12:41 am and is filed under Press Releases, ROAR Announcements. You can follow any responses to this entry through the RSS 2.0 feed. You can leave a response, or trackback from your own site. |
