求助M2设置
查看: 2208|回复: 7|   [复制链接]
酷爬 元老 Fans 发消息
发表于 11-6-6 01:46:13 |显示全部楼层 来自: 中国云南昆明
买了NOVAK M2,装自己的NA车,装车接通电源后后轮一直在转,前轮没反应,是不是要先设置啊?说明书中有个一键设置的说明,本人英文不好,看不明白,请谁设置过的告诉下怎么设置,或者帮忙翻译下这段:
STEP 5-one-touch programming
With ESC connected to (at least) a receiver and a charged battery pack, and the transmitter’s Aux/3rd channel (3Ch required for Dig) set to its middle position:
1. TURN ON THE TRANSMITTER’S POWER
2. PRESS & HOLD ESC’S ONE-TOUCH/SET BUTTON
3. TURN ON THE SPEED CONTROL’S POWER
With transmitter throttle at neutral, and still pressing the SET button, slide the ESC’s ON/OFF switch to ON position.
4. CONTINUE HOLDING SET BUTTON UNTIL RED LED COMES ON
5. RELEASE SET BUTTON AS SOON AS LED TURNS RED
6. PULL TRANSMITTER THROTTLE TO FULL-ON POSITION
Hold it there until the green status LED turns solid green. (Note: Motor will not run)
7. PUSH TRANSMITTER THROTTLE TO FULL-BRAKE/REVERSE
Hold it there until the green status LED blinks green.
8. RETURN TRANSMITTER THROTTLE TO NEUTRAL
The blue & red status LEDs will turn on solid, indicating that speed control is now ready to program the Aux/3rd channel that is used for the Dig feature. (Note: If using the Single Output Mode without Dig, ESC will exit programming here)
9. CHANGE TRANSMITTER’S AUX/3rd CHANNEL TO ONE END POINT
The blue & green status LEDs will turn on solid.
10. CHANGE TRANSMITTER’S AUX/3rd CHANNEL TO OTHER END POINT
The blue status LED will turn on solid & the green LED will blink.
11. RETURN TRANSMITTER’S AUX/3rd CHANNEL TO NEUTRAL
The blue, yellow, & red status LEDs will turn on solid, indicating that speed control is at neutral and that proper programming has been completed.
NOTE: If transmitter settings are changed, One-Touch Programming must be repeated. If you experience any problems, turn off ESC and repeat One-Touch.
NOTE: Whenever the One-Touch Programming set-up is performed, the speed control will automatically revert back to the factory-default settings.
本人在此先谢了。
小猪色色 超级元老 发消息
发表于 11-6-7 19:43:07 |显示全部楼层 来自: 中国北京
先说一下你的控是啥控
酷爬 元老 Fans 发消息
发表于 11-6-7 22:06:52 |显示全部楼层 来自: 中国云南昆明
回复 小猪色色 的帖子
谢谢小猪,NA的原车控。
mike194950 论坛元老 发消息
发表于 11-6-7 22:26:58 |显示全部楼层 来自: 中国四川雅安
NA的原车控???
NA好象没配控吧!!~~
maplelin 论坛元老 发消息
发表于 11-6-8 00:37:02 |显示全部楼层 来自: 中国福建厦门
NA没原车控。。。
老F 超级元老 发消息
发表于 11-6-8 07:33:59 |显示全部楼层 来自: 中国北京
要保证第三通道是比例的
酷爬 元老 Fans 发消息
发表于 11-6-8 08:44:59 |显示全部楼层 来自: 中国云南昆明
呵呵,表达错误,应该说是原车配的控,卖家说带四轮转向调节,不知道有没有老F说的比例,不知道能不能设置NOVAK M2的断传功能?
发表于 11-6-8 19:51:50 |显示全部楼层 来自: 中国浙江杭州
